#141 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
| The Following User Says Thank You to LimitedSlip For This Useful Post: | JD001 (03-18-2022) |
#142 |
Drives: Subaru BRZ
Anything is possible in the UK... deep fried Mars bars, deep fried pizza or pies!!
| The Following User Says Thank You to JD001 For This Useful Post: | LimitedSlip (03-18-2022) |
#143 |
Drives: FRS
Lets say you have a $2500usd budget and a totally stock FRS auto 2013
What would you upgrade and why? I am at a bit of a crossroads. I need more power off the dead stop to merge ( I posted another thread here about this ) in that I merge onto highways a lot and I get uncomfortable with the lack of pick up. I need to improve that. But, if I can't do that for $2500 total, what else would you do with a stock FRS and $2500? |
#144 |
Drives: 2017 Toyota 86 (860 SE)
Tires, maybe freshen up the suspension or a mild upgrade. An OpenFlash tablet will wake the power up a smidge.
#145 | |
Drives: 2020 Toyota GT86
This post sent using 100% recycled electrons.
#146 | |
Drives: 17 BRZ
2 years worth of customizations of tuning and smoothing out everything for AT (he makes tunes for MT also - but drives AT) Anyways, the low-end hesitation is gone. UEL header will aid in this area more than a EL header. Even the shifting and RPM limiter behavior with his tunes will shift and feel like butter. Highly recommended UEL Header $500-1200 depending on quality/brand - cats or no cats OFT $400/$500 Tune $50 Extra on tires or overpipe $200 |
#147 | |
Drives: FRS
| The Following User Says Thank You to KiokenFRS For This Useful Post: | Espi (04-11-2022) |
#148 |
Drives: red 2013 scion FRS
FRS OFT V2
so i just got an oft v2 and was wanting to do a pop tune using base timing, the mods on my care are tomie expreme uel catless headers, stock over and front pipe and an invidia n1 cat back exhaust would this be safe to do? If not what would you recommend?
#149 |
has a funny hat
Drives: 2014 BRZ Limited
| The Following User Says Thank You to pope For This Useful Post: | x808drifter (11-18-2022) |
#150 |
LMGTFY
Drives: 13 FRS, 91 Miata
Some examples...
Unnecessarily wide wheels and/or sticky tires. Staggered Tires/Wheels. HellaFail the car. (Oops sorry, HellaFlush) Any engine mods when you don't understand the car. That also includes FI. (Hell most don't understand any car.) Pop tunes. Electrical mods, when you don't know WTF you're doing. Swapping to a non airbag wheel in a non only track car. Cage in a non track only car. Half cage. Cheap adjustable coilovers. E85 only not spending the extra money/time to get a proper Flex Fuel setup installed. Widebody the car when it clearly doesn't need/warrant it. |
| The Following User Says Thank You to x808drifter For This Useful Post: | pope (11-18-2022) |
#151 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | x808drifter (11-19-2022) |
#152 |
Drives: 2015 FR-S
If you want to learn how to fix broken FA20s by all means go for it. You'll get plenty of practice.
| The Following User Says Thank You to Kittykate For This Useful Post: | Tcoat (11-20-2022) |
#153 |
Drives: 2013 scion fr-s 10
What are the three wires connected to the dashboard molding?
Taking the dashboard trim off, I’ve discovered three wires going inside the trim next to the radio. Does anybody know what these three wires are they are black, white and red going into a flat piece.
#154 |
Drives: 2014 ultramarine FR-S monogram
| New Member & have question? Read here first! | ichitaka05 | BRZ First-Gen (2012+) — General Topics | 6 | 10-22-2021 05:43 AM |
| New Member - paint question | kberkel | BRZ First-Gen (2012+) — General Topics | 21 | 03-26-2014 09:38 PM |
| New Member | FRSupra | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-20-2012 11:25 PM |
| New member | brz007 | BRZ First-Gen (2012+) — General Topics | 2 | 06-02-2012 09:37 AM |
| New Member/ Quick question | sikse7en | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 11-28-2011 08:57 PM |
