Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-06-2022, 10:58 PM   #1
Nicad
Drives: 2022 Cdn Spec White BRZ
Changing from C to Farenheit on display
I have a Canadian spec 2022 BRZ. Since i am old enough to prefer Fahrenheit when it comes to temp displays, I'd like to switch my car to degrees F. I went through the manual and settings but did not see if this is possible for the user to do , or do you need to plug into a dealer computer to set this up? I had no problem switching to Miles vs KM....but not temp. If you have suggestions I'd be thankful.
Nicad is offline   Reply With Quote
Old 04-07-2022, 12:14 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
are you talking about the gauge display or the hvac system?
Old 04-07-2022, 12:31 AM   #3
Nicad
Yes, as well as the outside temp display.
Old 04-07-2022, 01:21 AM   #4
soundman98
soundman98's Avatar
welcome to the rabbit hole!
HVAC is region-locked. i've got a candian-spec tacoma, HVAC is stuck in Celcius. after hunting dracula for a couple weeks well into the darkest corners of the internet, the best i could confirm were some vague reports that the only way to 'possibly' change the displayed temp to Fahrenheit is to replace the main body computer(display is a display-only, with no relevance to reported temperature), which is coded specifically to the vehicles other computers, and a dealer-only replacement item, and would be all billable hours, non-warranty, prices that could approach numbers with a comma in them... things went really into the weeds with whether anyone was allowed to alter previous programming to allow Fahrenheit in the new computer, and i'm still not entirely clear on it..
my 2014 brz has the same fundamental HVAC display, and the same limitations...
BUT!! the outside temp display should be alterable. it ought to be part of the change from kph-mph. on my tacoma, it's in the settings, under 'units of measurement'.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Tcoat (04-07-2022), timurrrr (04-07-2022)
Old 04-07-2022, 12:19 PM   #5
Nicad
Ok, well that ends that. I'll ask at the dealer as a just in case. Thanks.
The Following User Says Thank You to Nicad For This Useful Post:
soundman98 (04-07-2022)
Changing display color radio GT86/BRZ 2013 AEBRacing Electronics | Audio | NAV | Infotainment 0 12-08-2020 12:18 PM
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 04:50 AM
Changing color of radio display ProjectMidnight86 Electronics | Audio | NAV | Infotainment 2 04-28-2016 01:23 AM
CA-FI Heads Up Display XtremeMaC Electronics | Audio | NAV | Infotainment 3 08-18-2015 09:41 AM
Mpg display Dipstik-sportech BRZ First-Gen (2012+) — General Topics 18 11-26-2012 08:38 AM
