Drives: 2013 Subaru BRZ
Engine ticking shortly after new engine
I recently bought a 2013 brz and almost immediately spun a bearing. After taking it into the dealer and getting a new shortblock, I am hearing a ticking sound at certain rpms that sounds somewhat similar to a valve or rod issue. Any ideas as to what this may be?
#2 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | humfrz (04-04-2022) |
#3 |
Drives: 2013 FR-S Series 10
Thread useless without video
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#4 | |
![]() DANG, you are hard on engines! (sorry, bad joke - ).I'd suggest you give the new block a few miles to settle in, to see if the sound will go away (or you will get used to it). |
#5 |
Drives: 17 Asphalt 86
The direct injectors make a ticking noise while driving. Sounds sketchy if you don't know the sound.
#6 |
Drives: car
@boulderbrz could just be the injectors, a clicking that can be annoying.
Another tapping or ticking can be from the clutch throw-out bearing. Should have been upgraded to the new subaru part #, upgraded throw out bearing, which is more reliable than the factory bearing that came with early models. |
| Engine Ticking and Blowby | Blazer | Engine, Exhaust, Transmission | 13 | 12-09-2021 11:50 AM |
| engine ticking noise at idle | fog | Issues | Warranty | Recalls / TSB | 13 | 11-02-2020 08:51 PM |
| Ticking/rattling after engine install, now won't turn over? | Alfrz91 | Issues | Warranty | Recalls / TSB | 26 | 10-12-2019 09:48 AM |
| Ticking/rattling after engine install, turns into...? | Alfrz91 | Engine, Exhaust, Transmission | 0 | 10-01-2019 02:18 AM |
| Loud ticking from engine | Norotor | Issues | Warranty | Recalls / TSB | 8 | 04-24-2018 02:45 AM |
