Old 03-29-2022, 02:18 PM   #4481
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
CSG hasn't spoken up about how many they would like to stock as of yet, if at all. I have 5 additional over pre-order but they get first pick. Had to order the extra just to make it affordable for everyone. Not currently planning on doing any more runs these. Huge headache for no money.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
aKaGorganZola (03-30-2022)
Old 03-29-2022, 07:57 PM   #4482
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
BT
I, as well as the other purchasers of your kit I'm sure, appreciate the time/effort you've invested in these. It's very generous of you to share something that improves on the SC Kits performance !
Brewster is offline   Reply With Quote
The Following User Says Thank You to Brewster For This Useful Post:
B T (03-29-2022)
Old 03-29-2022, 08:22 PM   #4483
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Agreed. My remote map kit was great and my car runs so smoothly I can't imagine what it was like before this was an option.
TomR
ABQautoxer is offline   Reply With Quote
The Following User Says Thank You to ABQautoxer For This Useful Post:
B T (03-29-2022)
Old 03-29-2022, 09:52 PM   #4484
B T
Good News everyone. CNC parts arrived today. I've got to check them all for fitment and order a set of brass fittings I forgot, but they should ship out soon.
Old 03-30-2022, 08:13 PM   #4485
toast
Drives: 14 BSP Edelbrock BRZ
I saw a pic of one of your kits. So much nicer than version 1 that I welded up (poorly) out of aluminum. The 3d printed one didn't work because the plastic didn't survive?
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
B T (03-30-2022)
Old 03-30-2022, 08:17 PM   #4486
B T
Thanks Toast, the 3D printed one was never meant to be installed, just fit tested for the CNC model. Went through a couple iterations then sent off for machining.
Old 03-31-2022, 06:41 PM   #4487
B T
Well, minor setback, they didn't machine the NPT tap deep enough for a clean fitting install. Going to work on tapping it correctly this weekend. Everything else fits great.
The Following 2 Users Say Thank You to B T For This Useful Post:
aKaGorganZola (04-01-2022), Auto_egr (03-31-2022)
Old 04-01-2022, 12:04 AM   #4488
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Going above and beyond man. Thanks
aKaGorganZola is offline   Reply With Quote
Old 04-01-2022, 02:10 AM   #4489
Mr_Eyo
Drives: 2017 Toyota 86
Good news, new batch of remote maps supposedly shipped my way today.
I think I read that you ponied up for the tenth unit since you couldn't find any more interest, is that correct? If so, are you looking to unload it?
Mr_Eyo is offline   Reply With Quote
Old 04-01-2022, 02:53 PM   #4490
B T
I got ten orders and had to order an additional 5 just to keep cost low, so I have 5 extra. I've boxed them all up for shipping today. Worked on lengthening the NPT tap hole but marred the surface of test model in the process, so didn't go ahead with the rest. This won't affect performance, but it does cause the thread on the brass fitting to stick out farther than I wanted for aesthetics. Overall, not as happy with this CNC shop as the previous group buy but it'll work without issues. I've also included an extra o-ring in case you have any issue with the one I installed already not sealing. Still waiting on shipping addresses for some of you.
The Following 3 Users Say Thank You to B T For This Useful Post:
aKaGorganZola (04-01-2022), BAT_BRZ (04-06-2022), CSG Mike (04-01-2022)
Old 04-04-2022, 04:48 PM   #4491
bokehmon
Drives: 2014 DMG BRZ
Originally Posted by BrahmaBull1990 View Post
Got the car back! I had a leak at the catch-can outlet hose to the SC. The new JDL 4-2-1 header was installed as well. I’m ready for Spring!
Did you have to get your car reflashed to a k00G tune?
Mine's on a A01C, and I'm noticing the same issue.
(to be fair - i flashed the car myself... so my fault)
https://datazap.me/u/bokehmon/log-16...&data=12-31-44
bokehmon is offline   Reply With Quote
Old 04-04-2022, 10:10 PM   #4492
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Same tune and it has been fine. A little stumble at idle sometimes but really smooth while driving and doing pulls.
The tuner told me our stock sensor only hits 12.1 and he used the dynapack’s dual wideband sensors to tune richer under WOT. The AFR looks fine when cruising around.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-05-2022, 01:18 AM   #4493
ze12o
Drives: BRZ 2015 DGM
finishing up the S/C install, and while bleeding the clutch was able to hear the TOB noise.. its VERY squeky, especially with the hood / manifold out of the way..
  • i know, its been beat to death, but what clutch are you all running?
  • any feedback from CSG spec OS giken?
  • second choice ive been reading about is exedy stage 1?
  • is this a good time to change out spark plugs at 49k?
some notes:
probably wont be adding more power...(maybe...)
this is my DD
i track 2-3 times a year.
thanks all.
ze12o is offline   Reply With Quote
Old 04-05-2022, 01:22 AM   #4494
tomm.brz
Drives: brz 2017 hksv2
LOL, our sensor hit 12.1 only at stock, normally good tuner rescale it
Anyway that log I see... is full of bugs, as usual in your Country
I can t believe people spend like 500 usd or more to get such a bad tune, from a tuner who is obviously not informed at all in our car
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
