Old 03-25-2022, 05:52 PM   #1
jtiptonk
jtiptonk's Avatar
Drives: 2013 WRB Subaru BRZ Limited 2.0
Relay to turn off drl when turn signal is on
Hi! Would anyone be able to help me make a relay that turns off the DRL when the turn signal is on?
I’m looking to retrofit a 2013 brz with the 2017+ headlights and would like the DRL boomerang to turn off on the side with an active turn signal (which is the 2017+ oem functionality). Thanks!
jtiptonk is offline   Reply With Quote
Old 03-25-2022, 08:49 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
so there's 2 options that you can explore.
the first is a momentary-off. where the DRL only turns off for as long as turn signal light is on--so the drl/signal would alternate on/off when the signal is active.
this method just needs a relay, like this:
https://smile.amazon.com/Nilight-Aut...09&sr=8-4&th=1
wire in the turn signal to 85, 86 would go to ground as the relay activation, and then wire the feed to the drl's in through pins 30&87a-- 87a would be the car-side of the drl wiring, 30 would be the output to the headlamp.
the 2nd option is more OEM. it would make the drl shut off for the duration of the time the signal is on, so only the signal will flash.
using the same relay, you need to add a delay-off module, like from here:
https://www.wolstentech.com/products...delayrelay.php
everything else would wire up similar, the delay-off just comes in before the relay on the turn signal side. the 1or2 pin would connect to the turn-signal, the L pin would connect to the relay on 85. the delay-off also requires a separate power source.
humfrz (04-03-2022)
brz, electrical, headlights, lighting
WTB: OEM Turn Signal Relay beltax90 Want-To-Buy Requests 0 10-05-2020 12:56 PM
Diode Dynamics SmartTap Turn Signal Relay reh8388 Audio/Visual, Electronics, Infotainment, NAV 3 11-25-2019 04:37 PM
FS: Front/Back LED Switchback and Turn Signal with Relay - Concept 3/Vicious LED Rich1 Exterior Parts (Aero, Lighting, Etc.) 2 07-26-2013 12:04 AM
WTB: stock turn signal relay Cajun Interior Parts (Incl. Lighting) 1 07-23-2013 03:56 AM
