Old 03-13-2022, 10:11 AM   #1
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
New to audio, looking to upgrade.
I'm looking at the OEM Audio+ Front Speaker Upgrade for a 2015 BRZ https://oemaudioplus.com/product/front-speaker-frz/ and wanted to know if I need to or should upgrade the stock amp too? I'd realistically want a plug and play in the same spot if i did upgrade the amp. I'm not looking to put an sub in the trunk. I will also get a new head unit for android auto.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 03-13-2022, 10:33 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
oem+'s attitude has always been to maintain a plug-n-play solution to everything. that particular upgrade path of just the speakers is specifically intended to leave everything as-is in the vehicle.
the speakers that they sell have never been all that spectacular spec-wise--those are a maybe $150 upgrade from any other aftermarket audio brand. it's important to remember that the majority of the purchase cost with any oem+ purchase is in the backend installation simplicity(both instructions, and speakers maintaining toyota-spec connectors/wiring harnesses for direct-swaps) and post-purchase support.
Old 03-20-2022, 06:07 PM   #3
thevirushaus
Drives: FRS
It sounds like you want something plug and play. You should go for it but as previous poster mentioned you do lose quality for convenience. It should make a big difference compared to stock. If you decide to spend about the same amount piecing together your own system with the same budget, you will blow awayy the oemplus.
thevirushaus is offline   Reply With Quote
Anyone looking for OEM Audio Plus 450Q reference audio upgrade? Blueaudi18 New England 2 07-19-2017 12:09 PM
Looking for OEM AUDIO PLUS UPGRADE,OR ? SuperKazRacing Audio/Visual, Electronics, Infotainment, NAV 0 09-24-2013 07:37 PM
Audio Upgrade brian_c_m AFRICA 340 07-29-2013 01:06 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
OEM Audio Plus upgrade cgrey Electronics | Audio | NAV | Infotainment 6 09-14-2012 10:36 PM
