| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 2022 BRZ sport-tech
Oil temp guage, does the BRZ have it?
This guy mentioned that his BRZ doesn't have an oil temp guage when compared to the GR? Or is he referring to an actual numeric value of both oil and water temp?
Start @ 7:20. Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
| The Following User Says Thank You to Petah78 For This Useful Post: | dowroa (03-12-2022) |
#2 |
Drives: X5 35d, D90, CX-5 Turbo
I'm pretty sure the BRZ displays Oil Temp, but as a bar graph, not a digital (numeric) number as the GR does. Not sure Why Subaru and Toyota decided to do this differently, but would prefer the GR86 digital as the bar graph requires you to guestimate to a degree..
Check this thread Out.. |
#3 |
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
Check the BRZ manual on page 153. The first display page on the left side of the cluster will give you the battery voltage and the engine oil temperature in Degrees. You could make note of the temp in degrees and flip to the graphic display to see where that is. Do this at various temps and after a while you should be able to have a feel for how hot it is. My 2017 had oil and coolant temp gauges that allowed you to toggle between display numerically and relative graphic. My 2022 BRZ should be here next week and I will verify all this.
| The Following User Says Thank You to Flarpswitch For This Useful Post: | Petah78 (03-12-2022) |
#4 |
Drives: '22 Tacoma, '19 Macan, '22 BRZ
I'm operating under an assumption the 1/4 distance of the BRZ oil temp gauge is about 190F and the 3/4 distance is around 270F. Anything in between should be a good temperature/pressure. I've yet to see it go past the middle point when driving hard. For reference I'm running Liqui Moly 5w30 Molygen.
#5 |
TRACKBREAD
The bar graph on the BRZ has a labeled x-axis so I fail to see the problem here.
#6 |
Don't know that there is a problem, but it seems clear that some would prefer to see an actual number. In the photo you posted, you still have to guestimate what the oil temperature is. Granted, this is not much different than many gauges analog or digital, but I can see the preference of having a number instead, particularly for those that may be pushing the envelop on track days..
| The Following User Says Thank You to LRNAD90 For This Useful Post: | timurrrr (03-14-2022) |
#7 | |
TRACKBREAD
I don’t need the actual number to know if it’s hot/cold/normal. The bar gauge gives a much better at-a-glance view of the oil temp than a number does. The exact number doesn’t matter. 196 vs 198 doesn’t matter, they’re both normal temps. It’s much easier to misread a number on a quick glance than a bar graph. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Dzmitry (03-16-2022) |
#8 | |
Drives: 2018 Subaru BRZ Limited with PP
In either case, it's still a personal preference to each person. I can see myself preferring the number display over the bar graph despite what I said. |
#10 |
Drives: '13 Whiteout
It’s easier to glance down at a bar graph than trying to read a small number when on track. You don’t need exact, you need a general idea if you’re in the correct range or not
| The Following 2 Users Say Thank You to TommyW For This Useful Post: | Dzmitry (03-17-2022), Yoshoobaroo (03-16-2022) |
#11 |
Drives: 2022 GR86
Depends. I have a few seconds every lap to look at the exact number — at least while driving on the main straight. I'm ok reading the number.
Do I care about the precise number? If I'm evaluating the performance of an oil cooler — I do. But at that point I might as well use a data logger and look at the bigger picture after the session. For the "my oil is too hot and I should do a couple of laps of cooldown" a bar graph should suffice. |
| Prosport EVO oil temp Guage | Sojhinn | Audio/Visual, Electronics, Infotainment, NAV | 1 | 03-22-2016 11:25 AM |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
