Old 03-10-2022, 08:40 PM   #29
brzlegend
Drives: brz
"T"ing them will still cause fuel starvation if one pump is sucking air.
If the pumps have check valves the check valve will close when one pump looses pressure(sucks air) so you should still have pressure in the fuel system. This is with teeing the pressure side. You would also need to arrange the jet pump system to work in this configuration to your advantage. As far as burning a pump up running it dry it shouldn't hurt the pump considering it would no longer be under load and drawing very low current.
Staged systems have to have check valves on the secondary pump(s) if in parallel.
brzlegend is offline   Reply With Quote
Old 03-11-2022, 02:27 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I will have to test this with the stock pumps. "T"ing up top would be much easier.
Old 03-15-2022, 08:29 PM   #31
jacobe38
@slothbrz on IG
jacobe38's Avatar
Drives: Track BRZ - Supercharged
What is your opinion on a 2nd pump being always on, and always feeding fuel into the driver side basket?
Basically wiring it up along with the driver side original pump
I had planned to use a switch to control it but would simplify my life to have it just be always on, if there were no drawbacks
jacobe38 is offline   Reply With Quote
Old 03-16-2022, 04:50 PM   #32
brzlegend
Drives: brz
I would probably just use two stock pump baskets teed with two controllers parallel. You could put a filter (or sock)on the crossover tubes and run them to the back or side of the tank.
3d print some flapper doors or buy.
Best would be build a surge tank that replaced the basket then a factory basket feeding the the surge tank.
FS: OEM Fuel tank with pumps MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 3 06-02-2016 03:08 PM
Aeromotive 325 fuel pumps 1stGenBRZ86 Forced Induction 12 05-05-2014 06:22 PM
Please read if swapping fuel pumps Dipstik-sportech Forced Induction 5 06-17-2013 02:39 PM
*** Introducing the SBD290 DROP-IN Fuel Pumps for the BRZ/FRS/GT86 *** Visconti Engine, Exhaust, Bolt-Ons 21 03-08-2013 01:50 AM
SEMA 2012 Coverage - Deatschwerks Fuel Pumps and Injectors *Video Interview* Circuit Motorsports Engine, Exhaust, Transmission 0 11-13-2012 07:40 PM
