#15 |
Drives: Slowly
That works great until there is no more fuel on the rhs. The rhs pump continually runs dry and eventually fails.
Sent from my Nexus 6 using Tapatalk |
#16 |
Drives: Toyota GTS 86
Maybe they are using the float to turn off the rhs pump (speculation only).
I was very surprised they didn't install a surge tank given it is a dedicated race vehicle - but they didn't. |
#17 | |
The Dictater
Drives: '13 Red Scion FRS
The problem with the simple 1 pump drawing from a T into both sides is that unless you draw the EXACT right amount from each side (note: not necessarily even amounts) you will wind up emptying one tank faster. When one tank is empty, the pump starts drawing in air, and only air, from only that tank. The fuel in the other side would not be touched. If you don't have a float on either side and 2 gauges to monitor them, you could run dry without knowing it. Theoretically, you could treat each side as its own fuel tank and switch between them manually (aircraft style), but that defeats the purpose of a simple solution.
It seems to me that the best solution is to draw from one side only, and use some method to equalize the fuel level. My guess is that's why the folks mentioned below have their fuel system setup that way. Quote:
Edit: Im dumb. Just looked at the Hydramat thing. Looks like what I am saying doesn't apply... |
#18 |
Drives: Slowly
I'm not speculating, I've seen the dual pump setup fail. In fact, I've seen it fail on my dyno. My car has two hydramats, plus a surge tank and I'm just about to switch to a larger surge tank. Race cars should just use a fuel cell. Forget the race series down here as an example, a lot of things they do on those cars are pretty dumb.
#19 |
Drives: 2013 Asphalt FRS
Radium Engineering
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#20 |
Has anyone tried this out from Radium?
http://www.radiumauto.com/Venturi-Je...-Kit-P760.aspx Maybe add a hydro mat on the passive side to help with the pick up. |
#21 | |
@slothbrz on IG
Drives: Track BRZ - Supercharged
#22 |
Drives: 2017 BRZ Series. Yellow
I don't know if it's bye or I just missed it but radium has a dual pump setup now that utilities the stock pump location and with the fuel trapdoor that they have mostly if not completely eliminates the fuel starvation under hard cornering.
#23 |
#24 |
Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
I did not. The radium route is the way to go
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
| The Following User Says Thank You to RedFR-s For This Useful Post: | Ultramaroon (02-19-2022) |
#25 |
@slothbrz on IG
as in surge tank setup?
and when you say you did not, what exact method did you attempt? the T connection thing as suggested by the other user? ive recently spoken to some folks who had some success mounting a 2nd pump that fed the first pump's basket. so im wondering on the specifics thanks for responding! |
#26 | |
Drives: Crapcan
#27 | |
@slothbrz on IG
I wouldn't do the T method either....but I was just wanting clarity on what OP meant exactly by saying "it" didnt work. I plan to do what you are doing. But sounds like a simpler way. I plan to wire the second OEM pump in the passenger side to the same driver side power wire. And put a switch in the wiring there so its basically on or off. I got the tracbox and those racecargobrr switches and I plan to use one of those as the switch for this secondary pump. my plan is to switch it on while im on track and switch it off when I begin cooldown. and that's it. nothing fancier than that. I am also a wiring noob. I've touched about every bolt on the car but electronics is a new foray for me. as such i am open to suggestions if something I said sounds inadvisable. i do know of someone who used a Pi to basically turn on his aux fuel when he is on throttle. thought that was neat. but over my head. |
#28 | |
Drives: Crapcan
I will do a writeup on my setup when I put it together. At this point I am still grabbing fuel fittings that I will need. I want it all together to document it in one go.
| FS: OEM Fuel tank with pumps | MicheleAbbate | Exterior Parts (Aero, Lighting, Etc.) | 3 | 06-02-2016 04:08 PM |
| Aeromotive 325 fuel pumps | 1stGenBRZ86 | Forced Induction | 12 | 05-05-2014 07:22 PM |
| Please read if swapping fuel pumps | Dipstik-sportech | Forced Induction | 5 | 06-17-2013 03:39 PM |
| *** Introducing the SBD290 DROP-IN Fuel Pumps for the BRZ/FRS/GT86 *** | Visconti | Engine, Exhaust, Bolt-Ons | 21 | 03-08-2013 02:50 AM |
| SEMA 2012 Coverage - Deatschwerks Fuel Pumps and Injectors *Video Interview* | Circuit Motorsports | Engine, Exhaust, Transmission | 0 | 11-13-2012 08:40 PM |
