Old 03-08-2022, 10:19 PM   #19433
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
9 times out of 10 you will get more money selling it yourself.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
PenGun (03-08-2022)
Old 03-08-2022, 11:23 PM   #19434
soundman98
ProCrastinationConsultant
soundman98's Avatar
But at the cost of extra stress, hassle, and time. It comes down to what you value your time and sometimes sanity.
Tcoat (03-09-2022)
Old 03-09-2022, 12:26 AM   #19435
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
Cleaned up the engine bay a bit today. Thinking of a bit more engine bay bling, maybe a Mishimoto inlet tube and a K & N drop in filter. I’ve read it gives a few more hp, a little sceptical of this but it’ll clean up the engine bay a bit by getting rid of the sound tube.
Dirty Harry is offline   Reply With Quote
Old 03-09-2022, 09:19 AM   #19436
Greenbottle
Drives: 2015 Hyperblue BRZ
Did the door stay modification today. Quite easy to do thanks to advice on this forum.
Doors no longer auto close onto my legs.
Then, again after advice here, I used a hand sucker to remove excess oil from the sump via the dipstick tube. Really didn't want to get ramps and stands for such a simple job. Removed half a litre and the oil level is now just over the top mark, hot or cold. Much happier with it now.
Greenbottle is offline   Reply With Quote
The Following User Says Thank You to Greenbottle For This Useful Post:
Tcoat (03-09-2022)
Old 03-09-2022, 09:27 AM   #19437
Super, shiny reflective wheels... And got an aircraft for s bonus point
Ummmm
Maybe some left overpaint?
JD001 (03-09-2022)
Old 03-09-2022, 10:22 AM   #19438
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Don't know about the Mishimoto, but I have some experience with the K&N. At the old Bridgehampton course, I used to run from corners 4 and 5 all the way in 4th gear in my normally aspirated 944. With a K&N, I had to use 5th. That's the only change I made in the car.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
Dirty Harry (03-09-2022)
Old 03-09-2022, 02:00 PM   #19439
PenGun
Drives: Red 2019 Subaru BRZ
Yeah. I will have time, quite a lot of time and I'll get some numbers from the dealer as we approach the end of the year, and go from there.
Now its putting few miles on it, and keeping it sweet.
PenGun is offline   Reply With Quote
Old 03-09-2022, 02:21 PM   #19440
JD001
JD001's Avatar
Drives: Subaru BRZ
The wheels are so clean... Nice!
The Following User Says Thank You to JD001 For This Useful Post:
Old 03-09-2022, 04:53 PM   #19441
Dirty Harry
Cheers! Ironically didn’t touch those yesterday, did give the car a hose down on the weekend, usually do after most drives, so it stays pretty clean.
Old 03-09-2022, 05:04 PM   #19442
Dirty Harry
Hmmm OK, so it sounds like it made a meaningful difference.
Old 03-09-2022, 05:24 PM   #19443
soundman98
soundman98's Avatar
but then on the flip-side, nohavemsg has some experience where the higher-flowing filters destroyed dirt bike motors because the filters didn't filter enough anymore
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Dirty Harry (03-10-2022), Ultramaroon (03-12-2022)
Old 03-09-2022, 06:09 PM   #19444
norcalpb
norcalpb's Avatar
Hadn’t seen this done before, but I removed the factory dead pedal and installed a kartboy one. The holes on the Kartboy are .5” further apart than stock, but luckily the twins have a second, higher hole that is perfect for mounting.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
therealstoly (03-09-2022), Ultramaroon (03-12-2022)
Old 03-10-2022, 12:41 AM   #19445
Dirty Harry
OK. Has anyone on here had related problems with the twins though from dropping in a high flow filter? From what I’ve read K & N seem pretty reputable. But I guess there’s always a risk though, right?
Old 03-10-2022, 08:06 AM   #19446
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Does this fix the squishy-ness of the stock dead pedal?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
