Old 03-08-2022, 04:34 PM   #1
nwgabrz
Drives: BRZ Limited
C 112 code?
Hi,
I have a P3 vent gauge and usually when I get a CEL code it will readout P00XX, etc.. However, I recently got a code that read out as C 112. I could not find anything on a "C" code and was wondering what that was.
It doesn't seem like a CEL code as those output as "P0000" and not "C 000".
Anybody have any ideas?
nwgabrz is offline   Reply With Quote
Old 03-08-2022, 04:55 PM   #2
p1l0t
p1l0t's Avatar
Yeah C is a valid OBDII code letter but it's not one Subaru uses as far I know. Only P or U. Unless maybe it's a non-engine related code or something? When you scan your OBDII port with another device do you see the same code?
Attachment 210194
Old 03-09-2022, 02:00 AM   #3
https://www.yourmechanic.com/article...0System%20(ABS)
Old 03-09-2022, 10:55 AM   #4
nwgabrz
Drives: BRZ Limited
Attachment 210194
Hmm.. I'll have to pull out my bluetooth OBDII scanner and see if it scans the C code then. At least if it does, it will tell me what the issue is, since the Torque app pulls up both the code number and the issue. Will have to try it when I get home tonight.
I've edited the OP to add a photo.
P.S. your attached PDF doesn't seem to work for some reason.
The Following User Says Thank You to nwgabrz For This Useful Post:
p1l0t (03-09-2022)
Old 03-09-2022, 10:57 AM   #5
nwgabrz
Drives: BRZ Limited
Maybe! The code is 112 and not 1102 though. But it could be that it skips a zero? I am going to try my bluetooth OBDII scanner with the Torque app on the phone and see if it pulls this C code. I edited the OP with a photo of the code from the P3 gauge.
humfrz (03-09-2022)
Old 03-09-2022, 01:05 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
"U" and "C" are usually communication DTC's, "P" are engine DTC's. I could only find 2 C's on the DTC chart and that isn't one of them and neither pertain to our cars and should come up that I could see. I wish I could remember the one guys username here, he would know.
p1l0t (03-09-2022)
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 09:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 02:27 AM
