Old 03-06-2022, 06:44 AM   #1
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Clean rear interior window
using google translate.
Hello
I have cleaned it many times sitting in the back seats and simply using a microfiber cloth with glass cleaner and the result is good, although not the best. The problem is that the brake light makes it difficult or impossible to clean certain areas. Some time ago I disassembled the upper part of the light and when I put it back on it had lost grip due to a torn/broken tab, I had to buy another original one and spent about €150. Now I want to clean the glass very clean again, but how can I make sure that the same thing does not happen to me again?
Any trick so that the tab doesn't break again?
Thanks
Alastor is offline   Reply With Quote
Old 03-06-2022, 11:15 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
usually a screw and a washer can replace the plastic tabs.
i also replaced the 3rd brake light with this model. it both hides the grime at the top, and also makes it easier to clean the bottom of the window.
https://www.americanmuscle.com/highm...ight-9909.html
Old 03-07-2022, 05:07 AM   #3
Alastor
Alastor's Avatar
Thanks.
But I'm prefer don't replace OEM light brake.
Any people remove it for to clean the rear window?
Please say me your experience or say me how to remove the light, safety
Thanks to all.
Old 03-07-2022, 06:29 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Replaced that third brake light with an Intec third brake light. Window is super easy to clean now. The OEM third brake light (besides being in the way of your rear vision) has plastic rivets holding it in place if I remember correctly so if you take it out, you need another solution to put it back in.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
soundman98 (03-07-2022)
Old 03-07-2022, 08:14 AM   #5
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
This is what you need to reach those areas:
https://www.amazon.ca/Stoner-Car-Car...e%2C118&sr=1-6
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
The Following User Says Thank You to sygfrid For This Useful Post:
wolffbite (03-07-2022)
Old 03-07-2022, 01:21 PM   #6
Alastor
Alastor's Avatar
Thank you.
I have had that tool for more than 8 years, it was the first thing I used but in the end I realized that the result was not so good, so I decided to do it the usual way, sitting behind and looking up pressing against the glass.
I also tried another tool finer than the Stoner, but it left traces and in the end it looked ugly. They are good solutions but I have already tried them.
I don't want to change the brake light, it's more because of the problems involved in making this type of reform, because in Spain that modification could give me problems with inspections.
Old 03-07-2022, 01:22 PM   #7
Alastor
Alastor's Avatar
So much beautiful, but I don't want problems with ITV.
The Following User Says Thank You to Alastor For This Useful Post:
Wally86 (03-08-2022)
Old 03-07-2022, 01:26 PM   #8
Alastor
Alastor's Avatar
I will try with this video.
Old 03-13-2022, 06:39 AM   #9
Alastor
Alastor's Avatar
I decided not to remove the light, with a microfiber taking it from the sides and rubbing through the gap between the glass and the plastic of the light, I got good results.
The holes that remain below are already more difficult, but for now this does not matter to me.
Doesn't it happen to you that when it gets direct sunlight you see rubbing? No matter how hard I try with quality window cleaner and hairless glass microfiber, I can never get it perfect.
Wally86 (03-13-2022)
Old 03-29-2022, 12:32 AM   #10
Decep
Drives: 2013 FR-S Series 10
I've never cleaned mine and probably never will.. looks crystal clear somehow and i've never touched it.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Keeping The Interior Clean Skyhawk5247 BRZ First-Gen (2012+) — General Topics 31 09-30-2020 06:59 AM
So how do you clean the inside of the rear window? Dadillac Cosmetic Modification (Interior/Exterior/Lighting) 17 12-06-2018 05:28 PM
Advice to clean Rear window carpet DandoX Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 02-02-2018 12:15 PM
FS TX: AE86 GTS Hatchback Under 51k original miles, Clean interior mandm177 Cars for Sale/Trade 10 08-15-2016 11:18 AM
How to Clean your Interior and make it look better than NEW! Guzic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-08-2014 11:39 PM
