Old 03-06-2022, 10:08 PM   #1
boomslang
Drives: Toyota
Suitable flywheel holding tool?
Anyone have a P/N for a universal type flywheel holding tool that will work on the FA20?
boomslang is offline   Reply With Quote
Old 03-06-2022, 10:15 PM   #2
BlkTrax
Drives: Car
If you mean for torqueing the flywheel bolts to the crank.
Just use a flat piece of steel, drill one hole big enough to slide over the dowel bolt on the block and a second hole to loosely bolt into a flywheel clutch pressure plate bolt hole.
BlkTrax is offline   Reply With Quote
The Following User Says Thank You to BlkTrax For This Useful Post:
humfrz (03-08-2022)
ALL SOLD - OEM AT flywheel, torque converter, trans cooler, floor shifter frs_adrian Transmission and Driveline 2 12-24-2022 03:21 AM
OFT is really suitable for FI Systems? AEBRacing Software Tuning 17 08-16-2020 08:27 PM
Is Toronto suitable for the Lowered Life? daiheadjai CANADA 29 05-15-2016 04:03 PM
OFT Maps suitable for UK fuels Gringosteve Software Tuning 14 03-31-2016 07:40 AM
