Old 03-02-2022, 02:10 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Catted front pipe and mid pipe recomenations
I'm looking for recommendations for a catted front pipe and resonated mid pipe. Now that my header is catless, I thought that I might as well upgrade the rest of the system before retuning. I already have an aftermarket overpipe and a Borla axleback.
The quieter the better.
Old 03-02-2022, 02:56 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I really like my nameless front pipe. I run the 3" catted and resonated, they make a 2.5" as well. They are built to order though so the lead times can get a bit long and but they are built to what you want. So if you want to be able to mate it to a stock mid pipe they can put the correct flange on it to use the OE donut gasket. It replaces both the FP and OP so install may require that you unbolt the engine mounts and raise it up to snake it through.
blsfrs (03-02-2022)
Old 03-02-2022, 02:56 PM   #3
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Youre looking for a catted+resonated front pipe. JDL is the best option there is. But price will be your limiting factor. Get ready to spend $500+. I have a header, OP and catback. Front pipe is stock.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following User Says Thank You to Westen86 For This Useful Post:
blsfrs (03-02-2022)
Old 03-02-2022, 08:48 PM   #4
JOSEC
Drives: 2014 Subaru BRZ WRB
+1 on JDL Over-Frontpipe combo. I've had many JDL products stemming back to 2015 and all have been awesome, super high quality. Plus lifetime warranty. Can't beat that. Now I personally have Dual resonated 3 inch Over-frontpipe combo. and a 3 Inch JDL Single exit catback.
You can't go wrong with anything JDL. I also recommend Perrin's resonated catback.
JOSEC is offline   Reply With Quote
The Following User Says Thank You to JOSEC For This Useful Post:
blsfrs (03-02-2022)
Old 03-02-2022, 09:46 PM   #5
blsfrs
blsfrs's Avatar
Anybody have experience with PLM or Motiv products. Are they less expensive because they are that much lower quality?
Old 03-02-2022, 09:53 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That and PLM made knock offs of nameless and JDL parts.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (03-02-2022), whataboutbob (03-05-2022)
Old 03-02-2022, 10:06 PM   #7
blsfrs
blsfrs's Avatar
Do you have the Helmholtz resonator?
Old 03-02-2022, 10:24 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes.
blsfrs (03-03-2022)
Old 03-03-2022, 03:44 PM   #9
jflogerzi
jflogerzi's Avatar
JDL and Nameless Combo is Front Pipe+OP. It does not replace the mid pipe which is the s-pipe that connects to the muffler. 99% of catback systems replace this pipe FYI. Axlebacks do not replace this pipe.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
blsfrs (03-04-2022)
Old 03-03-2022, 07:13 PM   #10
norcalpb
norcalpb's Avatar
Works make a mid pipe that bolts to most axle backs but it seems like they want $10,000 for it.
https://store.worksmotorsports.com/W..._p/146.211.htm
The Following User Says Thank You to norcalpb For This Useful Post:
blsfrs (03-04-2022)
Old 03-04-2022, 10:32 AM   #11
blsfrs
blsfrs's Avatar
Maybe I'll get 2 of them so I have a spare.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (03-04-2022), norcalpb (03-04-2022), SuperTom (03-05-2022)
Old 03-04-2022, 05:54 PM   #12
jflogerzi
jflogerzi's Avatar
If your staying NA, stay with the stock mid-pipe and just get an axleback. If your going Catless Headers, you want as many resonators as you can get
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
blsfrs (03-05-2022), Espi (03-19-2022), kevaughan (03-09-2022)
Old 03-04-2022, 05:59 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have one, it's not bad with it.
blsfrs (03-05-2022)
Old 03-05-2022, 02:00 AM   #14
whataboutbob
AutoX-10/10ths every run
^ this
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
blsfrs (03-05-2022)
WTT Invidia catless front pipe for a resonated/catted front pipe nickmerronesucks Want-To-Buy Requests 3 05-10-2016 03:25 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 02:42 PM
Group Buy: TSUDO Performance Hi-Flow catted Test Pipe/Front Pipe/ Downpipe JonMotoring Groupbuys 65 08-27-2013 01:33 PM
WTB: Perrin Over Pipe + Catted Front Pipe + Cat Back (Resonated) coolaron Engine, Exhaust, Bolt-Ons 0 07-13-2013 04:37 PM
