Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-26-2022, 02:03 PM   #617
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Installed GS air filter that came out of my previous brz.
Stonehorsw is offline   Reply With Quote
Old 02-26-2022, 11:20 PM   #618
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
Catback, drift button, and bright LED reverse lights. Good day!
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 02-27-2022, 08:37 AM   #619
Courterman08
Drives: 2022 CWP BRZ Limited
Took delivery of it and within 3 hours I had swapped over all bulbs to LED, mounted and wired the dash camera, and detailed the interior. Today, since it’s not going to be as cold, I’ll do the first wash, paint decontamination, and prep for ceramic coating.
Courterman08 is offline   Reply With Quote
Old 02-27-2022, 10:31 AM   #620
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
Cusco rear lcas/Bilstein B8s/Swift Spec R. Been on the car a couple of days. Letting them settle then back for a proper alignment in a few weeks.
PBR is offline   Reply With Quote
The Following 2 Users Say Thank You to PBR For This Useful Post:
AK2112 (02-27-2022), Xed32 (02-28-2022)
Old 02-28-2022, 06:32 PM   #621
Rxgolf
Drives: 2022 GR
Finally made a decision on wheels and tires. We will see if the decision was good or bad when they arrive and mounted.
I can usually pick out what I will like with some certainty, but with fitment challenges this was more difficult.
I hope I like mine as well as I like some of those being posted here :-)
Rxgolf is offline   Reply With Quote
Old 02-28-2022, 07:29 PM   #622
ozafar
Drives: 2015 Scion FRS Release Series 1.0
What did you decide on?
I really wanted something with smooth spokes, no sharp angles, similar to the styling of the car. I decided on silver Enkei TSV 18x8.5 +40, with 245/35/18 PS4S
ozafar is offline   Reply With Quote
The Following User Says Thank You to ozafar For This Useful Post:
razgriz12345 (03-04-2022)
Old 02-28-2022, 10:38 PM   #623
eyeballs
Drives: '22 BRZ
Installed gr86 front mud guards. Since I'm lazy, I'm waiting until I swap the summer wheelset on to do the rears. Getting tint done tomorrow including the windshield.
eyeballs is offline   Reply With Quote
Old 03-01-2022, 02:23 AM   #624
jakeobie
Drives: RX-7, Soon to be 2022 BRZ
Did you wire the dashcam directly to the fuse box, or just into the usb port? I bought a nice dash cam setup that can be wired directly in but I'm a little afraid of pulling any interior trim (don't want to break any clips).
Got any tips or a guide on how you did it?
jakeobie is offline   Reply With Quote
Old 03-01-2022, 07:57 AM   #625
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Drove it from the dealer to the detailer. At least I've gotten one drive under the belt!
Blighty is offline   Reply With Quote
Old 03-01-2022, 08:00 PM   #626
Sym
Sym's Avatar
Drives: 2022 BRZ
There's really only one panel you need to pull to wire your dashcam- the end cap sorta thing on the side of the dash. Removing it lets you cleanly route the cables to your fusebox. Really easy to pop off a trim tool.
You can tuck most of the wire into the headliner/trim without having to remove anything.
Sym is offline   Reply With Quote
Old 03-01-2022, 09:18 PM   #627
Courterman08
I wired it directly to the fuse panel. Ran the cable up under the cover on the rear view mirror, across the headliner, down the A-pillar, and tied up the extra onto the car’s wiring harness.
Took some pictures but it was middle of the day so the lighting isn’t the best. I still need to trim the bolts from the mount.
Old 03-01-2022, 10:51 PM   #628
Rcode
Rcode's Avatar
Drives: Ford Fiesta ST, 2022 Subaru BRZ
Got Vorshlag camber plates installed onto my car today. Right now, I'm sitting at -2 on stock suspension. Still debating if that's too much or too little at the moment, I was told there's still some camber that can be had. The car is mainly used for track and spirited driving, so I figured something more on the aggressive side may be ok. Time will tell on that though. Otherwise, car turns in so much better on just a quick back road drive, I'm happy so far.
Some before and after, also a Viper.
Edit: Evidently the site doesn't like vertical photos, so some tilting may be required.
Rcode is offline   Reply With Quote
Old 03-01-2022, 10:53 PM   #629
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Have you done the upper/lower crash bolts yet?
Midnightsky is offline   Reply With Quote
Old 03-02-2022, 01:11 AM   #630
kaesu
Drives: 22 BRZ
Picked up some bushings/mounts! Looking forward to installing them
kaesu is offline   Reply With Quote
The Following User Says Thank You to kaesu For This Useful Post:
PBR (03-02-2022)
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
