Old 02-08-2022, 06:32 AM   #29
Youx
Drives: Toyota GT86 2012
It's definitely some sort of rattle outside of the engine. I don't think it's the AC compressor itself but notice that the rattle stops as soon as the compressor quits running. This is most likely because the engine quits laboring to drive it.
It's an odd one! Maybe a loose engine support. It's loud!
Yeah, it seems to start when the AC clutch pulley engages for the first time, and stops when it disengages, I made another video focusing on it.
https://youtube.com/shorts/NRkrvibHYvw
Youx is offline   Reply With Quote
The Following User Says Thank You to Youx For This Useful Post:
Ultramaroon (02-08-2022)
Old 02-08-2022, 09:17 AM   #30
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Run the engine with the belt off. See what happens.
Old 02-16-2022, 01:25 PM   #31
Youx
Removing the belt off seems a bit of a hassle? No idea how to do that (and put it back properly after?)
I've turned off the AC, so far no noise at all the few times I have started the car.
The Following 2 Users Say Thank You to Youx For This Useful Post:
blsfrs (02-17-2022), Ultramaroon (02-16-2022)
Old 02-23-2022, 08:08 AM   #32
obito.frs
team TEMPEST
obito.frs's Avatar
Drives: 2015 Scion FR-S
How willing are you to find the issue? Just take it to a dealer if you're not gonna try to diagnose it yourself. Taking off the belt isn't difficult, and a quick YT search will show you the process.
You're coming to a forum to ask for help, help was given, and you're like "nah that's too hard, why can't y'all immediately diagnose my car based on my very detailed description of 'ta-ta-ta-ta-ta'?"
Learn to work on your own platform. It'll help you in the future, and, in turn maybe you'll be able to help someone else. Otherwise, just go to the dealer and pay $200 for them to half ass the diagnosis themselves.
"I don't want to regret the way I lived"
obito.frs is offline   Reply With Quote
Old 02-28-2022, 09:08 PM   #33
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
As a non-professional wrench, I understand.
I was "jest ah messen wich" ol Ultramaroon -
hahahah, ahh, gotcha
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following User Says Thank You to JohnH For This Useful Post:
humfrz (03-01-2022)
Old 02-28-2022, 09:12 PM   #34
JohnH
Professional wrench
one of the reasons I bought this car is that its SUPER easy to work on, at least under the hood. The belt is nearly as easy as opening the trunk. Im not kidding. Put a tool in the tensioner, and detension it. then slide the belt off. Start the car, and listen to the noise or lack of it. Put the belt back on and try again. This really is the only way to isolate if its related to anything spinning by the belt
225/45VR17 RT660s
The Following 2 Users Say Thank You to JohnH For This Useful Post:
humfrz (03-01-2022), Ultramaroon (02-28-2022)
Old 02-28-2022, 09:24 PM   #35
It is ridiculously easy to remove the belt on this one, especially if the stupid noise generator has already been removed.
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 03:21 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
Perrin CBE crackling noise during cold start tracerit Engine, Exhaust, Transmission 8 02-26-2015 03:43 PM
Rubbing noise on cold start only in reverse? brsaresmgs Issues | Warranty | Recalls / TSB 2 01-18-2015 07:15 PM
Cold Start Clunk Noise Luckrider Issues | Warranty | Recalls / TSB 6 11-28-2013 05:02 PM
