#29 | |
Drives: Crapcan
The easiest guide that I found is the one by steve99. I know guys like him, tomm.brz, and kodename47 are pretty knowledgeable on that stuff. I know enough to get myself into, and sometimes out of trouble. This is the thread I used to tweak the maf scaling my car and it worked pretty well. I'd put a bit more mileage on your's before changing anything though. https://www.ft86club.com/forums/showthread.php?t=64790
#30 | |
Drives: 2013 Scion FRS
Now it will get down to high -7 low -8 and then go back to high -11 to low -12. AFR is much more consistent. Yeah i have to run around and do some stuff tomorrow. By the time Im done i should have that 100 miles. Then I’m going to double check everything and if it doesn’t change I’m scaling. Sent from my iPhone using Tapatalk |
#31 | |
Before i even start the car my diagnostics say that my ltft is -5.6 is this normal? Sent from my iPhone using Tapatalk |
#32 |
Drives: Crapcan
I wouldn't worry about it. May just be showing you the last value.
#33 | |
Something seriously wrong?
Where can i buy a new o2 sensor gasket? Mine is done and after reinstalling I’m throwing a code for my first 02 sensor. I cleaned my maf again and now my afr is stuck at 14.69. Have i trashed it now as well? Sent from my iPhone using Tapatalk |
#34 |
Drives: Crapcan
Without seeing a log or knowing the code I can't tell you what's going on. The ECU pulls the afr from the O2 so maf may be fine. I'd really only fix issues and not mess with anything else. Let it hit 100 miles minimum then start logging. Through your previous logs it didn't look like you had an exhaust leak and it looked like the maf was reading fine. O2 sensor gaskets can probably be picked up at a local parts store.
#35 | |
Im just getting the code for the first O2 sensor. I forgot that the O2 sensor affects afr as well. I got a new one coming and if the issue isn’t solved after the new O2 and washers then ill rescale. Even though I had the O2 sensor code the idle was good so im hoping its fixed. I cleaned entire intake, throttle body, and changed to a new freshly oiled filter. Along with re torquing the headers and screwing up my O2 lmao. Sent from my iPhone using Tapatalk |
#36 |
Are you fouling your MAF with too much oil? That is one of the two reasons I steer clear of reusable filters. That and, without increasing cross-sectional area, the only way to get an air filter to flow better is by reducing filtration.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (02-28-2022), soundman98 (02-26-2022) |
#37 | |
![]() (it's a slow day in Puyallup - )
#38 |
That doesn't make the air filter flow any better. It just sucks at it harder.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (02-27-2022) |
#39 |
#40 |
It's physics, old man. Don't hurt yourself.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (02-27-2022), soundman98 (02-28-2022) |
#41 |
Drives: brz 2017 hksv2
But it s forced induction so tecnically the engine isn t only sucking.. The charger is doing its blow job even when valves are closed
#42 |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
| Something is wrong S/C | Smaay | Forced Induction | 25 | 01-09-2020 10:52 PM |
| E85 gone wrong | MGPAX | Software Tuning | 34 | 03-17-2016 10:53 PM |
| What did I do wrong? | Hags86 | Tracking / Autocross / HPDE / Drifting | 8 | 02-25-2015 01:36 PM |
| HELP! WRONG GAS IN CAR | nabil_frs | Issues | Warranty | Recalls / TSB | 85 | 04-01-2014 01:44 AM |
| What's wrong with this car? | Suberman | CANADA | 41 | 01-14-2014 12:35 PM |
