Old 02-21-2022, 02:32 PM   #1
Christian628
Drives: 2013 Scion FRS
Something seriously wrong?
I put on gruppe-s UEL headers, overpipe, and replaced the gasket on my Invidia n2 a couple days ago. Fuel trims were slightly above -5 and I was going to collect the logs this week. Noticed today while idling at work that my LTFT was -13.2. When I got home I reflashed the off the shelf stage 2+ tune in thinking maybe it was something I have changed in the tune with the UEL headers causing it. It’s still wanting to climb up to high negative LTFT sitting at -9.8 after just a couple of minutes. I cleaned my MAF Sensor before doing the reflash. I don’t hear a leak and I’m using grim speed double thick gaskets. The O2 sensor that I can reach from opening the hood is nice and tight. Not sure where to go from here other than jacking up the car and trying to tighten the second O2. I’m running a mishimoto true cold air intake. Which I was told had basically stock maf scaling. Please someone help.
Christian628 is offline   Reply With Quote
Old 02-21-2022, 02:52 PM   #2
jflogerzi
jflogerzi's Avatar
Check for leaks at all connection points
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 02-21-2022, 03:32 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What intake?
Also need a lot more info, you usually get better help posting a log to datazap.me and the guru's can help you out. Check out steve99's thread on logging. Having -13.2 LTFT doesn't give us any info since it has no context. If that was a cold start then I wouldn't think anything of it. If that was full operating temp and at idle, that is a different story.
https://www.ft86club.com/forums/show...01#post1842501
Old 02-21-2022, 04:12 PM   #4
Christian628
Leaks where? Intake or exhaust?
Old 02-21-2022, 04:13 PM   #5
Christian628
What intake?
Mishimoto true cold air intake.
Full operating temp at idle.
I know how to log. What do I need to log? Same stuff that I would log for rescaling?
And just it idling or drive around a little bit?
Old 02-21-2022, 06:11 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
since you reflashed, car needs to learn new setup so you need to drive around.
i would datalog normal driving for 10~15 min and WOT from 3rd gear of 3K RPM to redline for 2~3 runs and post logs
Old 02-23-2022, 12:22 AM   #7
Christian628
What intake?
I have one of just idle if you want it.
https://datazap.me/u/christian628/lo...9?log=0&data=1
Old 02-23-2022, 12:23 AM   #8
Christian628
Old 02-23-2022, 09:27 AM   #9
zc06_kisstherain
Drives: SWP BRZ
probably not.
I am not expert on reading datalogs either
but here's my old file for local and highway driving around. change your data type of category. it's not enough information. add afr, STFT, LTFT, ADV, etc (look at mine)
https://datazap.me/u/zc06kisstherain...y?log=0&data=1
GL
Old 02-23-2022, 04:35 PM   #10
Christian628
probably not.
GL
Do you all not have the ability to click on those values to add them to the chart? I don't understand how to work this website.
Do these links work? I had to do WOT in 2nd gear I read that was fine. Not a lot of straight roads around me that are safe for me to redline 3rd gear.
https://datazap.me/u/christian628/lo...7-8-9-10-11-12 Driving around
https://datazap.me/u/christian628/lo...7-8-9-10-11-12 WOT 2 Gear
https://datazap.me/u/christian628/lo...7-8-9-10-11-12 WOT 2 Gear 2
Old 02-23-2022, 06:21 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you using the OTS Stage 2 maf scale or did you change it?
Old 02-23-2022, 06:57 PM   #12
Christian628
I have not touched maf scaling at all and I’m on the normal stage 2 + oft tune
My intake is supposed to be practically stock scaling.
Take a look at my logs. The moment I go wot my trims are acceptable. I haven’t taken a look at the trims for me just driving around yet. Going to take a look when I get home from work.
Old 02-23-2022, 07:03 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You need to rescale the MAF.
Closed loop vs. open loop. That is why you need to log injection mode. It is all in the link I put in previous post along with other info if you look in steve99's sig.
Old 02-23-2022, 08:04 PM   #14
zc06_kisstherain
Drives: SWP BRZ
You need to add them in your OFT or ECUTEK. Not from datzip
Sent from my SM-N986U using Tapatalk
Something is wrong S/C Smaay Forced Induction 25 01-09-2020 10:52 PM
E85 gone wrong MGPAX Software Tuning 34 03-17-2016 10:53 PM
What did I do wrong? Hags86 Tracking / Autocross / HPDE / Drifting 8 02-25-2015 01:36 PM
HELP! WRONG GAS IN CAR nabil_frs Issues | Warranty | Recalls / TSB 85 04-01-2014 01:44 AM
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
