Old 02-14-2022, 09:17 PM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Tow strap install - where?
Curious for track cars where you are installing the tow strap?
one like this. https://www.amazon.com/Sparco-01612R.../dp/B00BG423YA
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 02-14-2022, 09:58 PM   #2
RhythmAddict0
Drives: Porsche
Front and rear tow locations
Sent from my HD1907 using Tapatalk
RhythmAddict0 is offline   Reply With Quote
Old 02-14-2022, 10:25 PM   #3
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Thats where I would like them to be but I'm not sure how to install them securely. The factory tow hook bolt is too large for the hole in the mounting tab for the strap. Just bolting to outer shell of crash bar doesn't seem like a good plan.
Sent from my SM-G960U using Tapatalk
Old 02-14-2022, 11:40 PM   #4
otter
Drives: 22 BRZ
Look for a strap that's assembled with a threaded rod that fits Subarus.
otter is offline   Reply With Quote
The Following 2 Users Say Thank You to otter For This Useful Post:
bmacfrs (02-20-2022), Opie (02-19-2022)
Old 02-14-2022, 11:54 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
the ford focus rs my buddy sent me a picture of is any sort of seriousness, you simply zip tie it to the plastic bumper.
Tcoat (02-22-2022)
Old 02-15-2022, 11:22 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
You can try an adapter like this:
https://www.evasivemotorsports.com/s...aru-brz-13-20/
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Old 02-15-2022, 11:48 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
https://raceseng.com/tug-strap-model-specific
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
bmacfrs (02-20-2022), therealstoly (02-20-2022)
Old 02-19-2022, 08:21 AM   #8
Jstyle
Jstyle's Avatar
Drives: 2020 86
So just to verify that I’m reading this right, I can just secure my car by the front me rear tow hook? I have the Raceeng two\recovery hooks already mounted so I can just get a heavy duty ratchet strap and hook it to that?
https://www.ftspeed.com/part/01x-361...k#.YhDgS4FOmfA
https://www.rallysportdirect.com/par...-hook-rear-red
Jstyle is offline   Reply With Quote
Old 02-19-2022, 10:28 AM   #9
soundman98
soundman98's Avatar
are we talking recovery from a track off moment, or trailer tiedown? because i would never ever use the horizontal bumper recovery points for vertical trailer tiedowns. somethings going to give, and it won't be on the trailer.
Tcoat (02-22-2022)
Old 02-19-2022, 10:56 AM   #10
Jstyle
Jstyle's Avatar
Drives: 2020 86
From a trailer tie down. If that’s not a good idea then cool, just wondering what I need to get so I can secure it down to my new trailer.
Old 02-19-2022, 11:02 AM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
For trailer tie down, I installed E track, and use straps like these. Great for low profile cars.
RT-BRZ (02-19-2022), soundman98 (02-19-2022)
Old 02-19-2022, 01:10 PM   #12
soundman98
soundman98's Avatar
yep, the tire tie downs are nice. or you can alternately tie down to the lower a-arms on both ends, but that requires getting under the car, which some don't like.
all the rules of this video apply, you just don't have solid axles to attach to.
Old 02-19-2022, 01:16 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
There are two tie hooks under the front of the car on each side just in front of the tires.
strat61caster (02-21-2022), Tcoat (02-22-2022)
Old 02-19-2022, 01:28 PM   #14
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I use the 2 front factory tow hooks plus the factory T-Hook slot locations just in front of each rear tire....need a T-Hook like this to use...then the car is strapped using the body, not the suspension.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
bcj (02-20-2022)
Takata Tow-Strap Install JCFRS Cosmetic Modification (Interior/Exterior/Lighting) 4 09-25-2017 04:23 AM
Tamara tow strap Dreyup Cosmetic Modification (Interior/Exterior/Lighting) 13 07-09-2017 05:03 PM
Tow strap for bars FutureFT86 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-17-2017 08:01 PM
Takata tow strap Thatguyjeremy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-20-2015 10:25 AM
rear tow strap karma003 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-23-2013 10:00 PM
