#141 |
Drives: 18 Brz (Sold) / 22 BRZ
I think it is required to do 100% checking on end of line for headlights adjustment.
#142 |
Drives: 2018 Subaru BRZ 50th Anniversary
700 miles of twisty roads this weekend, here’s a few quirks to add!
1. In my BRZ, there seems to an rpm threshold about 3.5k rpm where the throttle sensitivity raises up. During break-in, I’ve gotten used to the lower throttle sensitivity. This leads to a “Jim makes Dwight’s phone slightly heavier every day moment” where I am downshifting 4th into 3rd right at the cut-off results in wayyy higher revs than expected. The same pedal blip at 3k rpm and 3.5k rpm rev the engine to 4k and 6k respectively. 2. There are a bunch of “>PP<“ embossments around the inside metal of the car (in th hood, above the bumper when the trunk is open, etc. I’m guessing this means something like a paint protection mounting point (idk), but it might be worthwhile to bring your BRZ to the nearest pokecenter and help restore some poor, tored Pikachu’s move PP. 3. The car really lets you know its on when it starts up. Not with sound, but with the feeling of the engine whirring to life. I feel this much more than in a bigger car like my STI. 4. Pedals are far enough apart that I need to use big boy heel-toe technique, not the “left toe, right ball” technique I find more comfortable on cars with tight pedals. Luckily, the brz has plenty of room in the pedal box to fit my foot sideways. 5. Slushy, snowy dirt will very easily pile up in the fender vent, wheel bezels, etc. and dry there. Notice this a tad more than with other cars. 6. The center console has enough space above the cupholder plastic that I can place an iPhone X with a thin case laying horizontally over both cupholders and close the console lips over it. This is the preferred way to keep a phone connected to carplay and secure while driving. The phone is snug and won’t budge like this even with some sudden g forces. 7. I can’t find the trunk locker yet like my old BRZ had - will check the manual later. (These are quirks as I see em - car review and comparison to my sti, as well as technical issues will be in their appropriate threads) Sent from my iPhone using Tapatalk |
#143 | |
Drives: On order: 2022 ISM BRZ Ltd
This car really is enjoyable to drive, even before break-in is over. With my 2017, there was always something not quite right with the feel in multiple areas, but this is instant love. I'd still like to get a used Carrera when the market comes back down to earth, but for roughly $30k, I think this car is a pretty unbeatable driving experience. |
| The Following User Says Thank You to slipstream8 For This Useful Post: | McMCOO (02-06-2022) |
#144 |
Anti-Social Media
Drives: 24 GR86 Premium MT is on the way!
Luckily I ordered and received a functional auto-dimming mirror before the car arrived. I may still tint.
| The Following User Says Thank You to McMCOO For This Useful Post: | Midnightsky (02-06-2022) |
#145 |
Again, it is very likely the sensitivity is an ounce or two, as long as that allows for current to flow through it. it has nothing to do with weight.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#146 | ||
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Between the unfocused aftermarket LED bulbs throwing glare all over the place, people driving all the time with their high beams on, or those lovely aftermarket LED bars that are becoming popular, my headlights are puny by comparison and no one even notices. |
#147 |
Anti-Social Media
Maybe this is not directly 2nd gen twins related, could just just be android auto: it appears voice commands in android auto do not go through the cars's microphone, but directly to the mic on the phone. I like to plug my phone into a 12 inch cable in the armrest and close the lid. It's great like that. The only issue is that I have to pop open the armrest to give voice commands.
I might try a Bluetooth to android auto adapter and see if that changes anything. |
#148 |
Spelling Impaired
According to the manual, in order to trigger Android Auto voice controls it takes a long press on the "voice" button on the steering wheel vs a fast press which just triggers the car's voice controls.
Have you tried that? I typically only use voice controls for calls and haven't tried anything yet on Android Auto to verify if the manual is correct. |
#149 |
Anti-Social Media
I can try that. But here's another use case: SMS message arrives, I push the button to have not-Siri read it. When complete, it asks if I want to reply. It cannot hear my response unless the phone is out in the open.
I didn't notice this in the 2020, but I had the phone in a little holster attached to the ouside of the center console. |
#150 | |
Drives: 2022 BRZ Limited SBP
I would put the head unit in Dealer Mode and then test the car’s mic. Sent from my iPhone using Tapatalk |
#151 |
Drives: '22 BRZ
Am I crazy, or does this car limit throttle under braking? Say, while heel-toe downshifting? I can see how this makes heel-toeing a bit more foolproof, because you can't really over rev. But it's definitely something I've noticed that I need to adjust when I drive it.
#152 | |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
#153 |
Drives: '22 BRZ
Agreed. It's pushing me to consider a tune when the time comes. I've also noticed a change in throttle response as the car is nearing complete warm-up temps. Obviously, throttle response and general engine behavior is different during the warmup; I'm generally delicate with the throttle during it. But once the oil is around 120-130, the engine revs strangely freely. I'll over-rev my first downshift every time in this car. But once the oil has reached a rough 190, the throttle is much more predictable.
#154 | |
Drives: 2023 BRZ Limited
| BRAINDUMP - FT86 Quirks, common fixes and when things need upgrading | Aztec | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 08-28-2015 05:44 PM |
| Magazine features | crouchy35 | AUSTRALIA | 1 | 06-03-2013 05:59 PM |
| Interesting features on the FR-S... | Senzai | Scion FR-S / Toyota 86 GT86 General Forum | 59 | 05-08-2013 04:41 PM |
| Strange Quirks | Aznek | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 08-15-2012 09:40 AM |
| FR-S Standard Features | zAnSh1n | Scion FR-S / Toyota 86 GT86 General Forum | 182 | 04-04-2012 04:23 PM |
