Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-03-2022, 02:07 PM | #1 |
Drives: 09 vw gti
Rubbing/shutter sound after coilover install...
I just installed a new clutch/flywheel and coilovers all at the same time. The clutch is working perfect. I'm getting this odd shuttering noise as soon as i hit 60mph everytime and the faster i go the louder it gets. It's sounds like like the tires are rubbing against the fenders but i checked the tires and i don't see any cuts or rubbing marks on them. There is no noise when I'm going under 60mph. Any ideas? I haven't got and alignmeny yet. At first i had them as low as they go so i thought it was too low. So i raised it almost an inch and half but still makes the noise..... please help.
02-03-2022, 02:14 PM | #2 |
Drives: 09 vw gti
Another thing i forgot to put back the under panel. But i don't think that wuld have anything to do with it. I live in Florida does the car need the panel? Should i put it back on?
02-03-2022, 06:37 PM | #3 |
Drives: 09 vw gti
Fixed it. It was because i didn't put the under panel.
The Following 2 Users Say Thank You to nickdd6237 For This Useful Post: | soundman98 (02-04-2022), whataboutbob (02-03-2022) |
02-03-2022, 09:15 PM | #4 |
Lol did the air at 60mph cause your transmission cover to fold back and grind on the ground? I damaged mine that way, didn’t think I’d need the metal cover for a quick little drive to the hardware store.
Also yes to always having that metal cover on when driving. It not only helps siphon out engine heat but also makes the car more “slippery” going down the highway. |
02-03-2022, 10:32 PM | #5 |
AutoX-10/10ths every run
Although it looks like you fixed your issue, I'd advise getting your ride height set where you want it and getting an alignment done ASAP. If you don't, you might need an alignment AND a new set of tires sooner than you'd like.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | nickdd6237 (02-06-2022) |
02-06-2022, 10:40 PM | #6 | |
Drives: 09 vw gti
The Following User Says Thank You to nickdd6237 For This Useful Post: | norcalpb (02-07-2022) |
02-06-2022, 10:43 PM | #7 |
Drives: 09 vw gti
Yes i know i bought 16" rpf1s. I just need to get tires for them So I'm just ride out the old tires i have on it now. Then get the alignment asap when i put the rpf1s and new tires on.
Similar Threads | ||||
Clunking sound after coilover install | Dee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-22-2018 04:12 PM |
Horrible bucking and shutter after clutch install | Scikotic | Engine, Exhaust, Transmission | 32 | 07-12-2016 08:10 PM |
Weird Sound After Coilover Install (when moving steering wheel left and right) | taimysho0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 07-20-2013 01:18 AM |
Rubbing sound? | Mo707 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-15-2013 11:06 AM |
Tire rubbing sound, Please Help | dco107 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-11-2013 10:05 AM |
