Old 02-06-2022, 03:14 PM   #1457
2015firestormFRS
Drives: 2015 firestorm scion FRS
fdf mantis angle kit vs. PBM vs wise fab? thoughts, opinions?
2015firestormFRS is offline   Reply With Quote
Old 02-22-2022, 12:24 PM   #1458
obito.frs
team TEMPEST
obito.frs's Avatar
Drives: 2015 Scion FR-S
Cool
I've heard the best about the FDF Mantis kits, I know a couple guys with them (86/350Z) and they rave about how great they are. Super solid kits, fairly simple to install, good adjustment, etc.
I'd say WiseFab is a close second, I can't say much for PBM but I myself am planning on running the FDF kit coming up
"I don't want to regret the way I lived"
obito.frs is offline   Reply With Quote
Old 05-27-2022, 11:59 PM   #1459
DiscoQuinn
DiscoQuinn's Avatar
Drives: 2017 BRZ
If you've got PBM version 1 knuckles and want to sell, get at me ASAP
DiscoQuinn is offline   Reply With Quote
Old 10-23-2022, 09:45 PM   #1460
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
If I'm having issues with clearance with the side walls after installing longer tie rods should I grind off the sections its hitting or install spacers / smaller wheels?
rilagin is offline   Reply With Quote
Old 10-25-2022, 04:01 AM   #1461
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
You might want to share a picture as well as your tire size and wheel specs (diameter, width and offset)
Falkon240 is offline   Reply With Quote
Old 10-25-2022, 06:55 PM   #1462
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
I'm not at home and I'm really stupid so I don't have all that info. I'm running 17'' standard wheels and -2* camber in the front. I have the Megan inner tie rods and P2m outer tie rods.
Old 10-28-2022, 02:31 PM   #1463
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Going off what you're saying, if you're running adjustable outer tie rods and the tie rod is hitting your inner wheel barrel, you could push the wheel out with a spacer.
Take some pics and share the specs when you have a chance.
Old 11-18-2022, 02:12 PM   #1464
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
After putting on spacers and maxing out the camber the only place its rubbing now is this small portion of the frame just on one side (probably due to frame damage). I assume I just take an angle grinder to this, shave it up a bit and I'm done right?
Old 11-20-2022, 01:55 AM   #1465
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I'd prob take a hammer to that.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Old 11-26-2022, 10:56 PM   #1466
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
That did the trick, I think I'll switch to 16 inch wheels once I finish off these tires so I don't have to run a ton of camber all the time and keep the additional steering angle thanks for the help
Old 11-30-2022, 02:05 PM   #1467
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
You can also run smaller tires. 235/40/17 or 215/40/17
How much is "a ton" of camber? You'll want somewhere around -4* ideally for drift.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 12-03-2022, 03:33 PM   #1468
rilagin
Shitbox enjoyer
rilagin's Avatar
Drives: BRZ (2013)
Im at -3.5. Is there any reason not to run 16 inch tires? I feel like I could take off the camber when I felt like it and not rub if they were that small.
Old 12-05-2022, 12:17 PM   #1469
terboboost
terboboost's Avatar
16" wheels will limit your brake caliper size, but should be fine for non-PP brakes. In addition, 16" tires will most likely have a larger sidewall, which can decrease overall performance/feel, compared to a smaller sidewall on a 17". Other than that, it's just a question of style preferences.
-3.5* front camber is pretty good for drifting. I'd say you should have more negative camber.
Old 12-05-2022, 02:08 PM   #1470
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Happy to see you here. Perhaps we can wake up the sleepy drift community on this board.
IG
2013 Scion FR-S
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
