02-04-2022, 05:58 PM | #351 | |
Drives: 2022 BRZ Limited
02-04-2022, 08:44 PM | #352 |
Drives: On order: 2022 ISM BRZ Ltd
If that measurement to the front shock perch is accurate enough, you'd have about 0.20" of clearance (10mm closer = 0.394" closer). Adding camber might close the gap? I don't have a strong grasp of suspension geometry.
The Following User Says Thank You to slipstream8 For This Useful Post: | Fletch (02-05-2022) |
02-04-2022, 08:47 PM | #353 |
02-04-2022, 08:54 PM | #354 | |
Drives: 2022 BRZ
Sent from my SM-G981U1 using Tapatalk
'91 Fc3s Turbo
'22 Brz Limited MT Too Many motorcycles. |
02-04-2022, 10:16 PM | #355 |
Drives: 22 WRB BRZ Limited
The Following User Says Thank You to 86 & Co. For This Useful Post: | slipstream8 (02-04-2022) |
02-05-2022, 12:49 AM | #356 |
Drives: 2022 GR86
02-05-2022, 11:30 AM | #358 |
Drives: 2022 GR86
02-05-2022, 12:24 PM | #359 |
Drives: 2022 crystal white BRZ
02-05-2022, 10:54 PM | #360 |
02-06-2022, 10:01 AM | #361 |
I was for a little bit and I had no rubbing, even over bumps and rough pavement, but as pointed out above I misquoted the specs of my wheels. They're ET42, not ET45. You can run a 3mm spacer to bump them out though and the effect should be the same. 3mm is about the most I would run with the stock wheel studs, as that would only give about 7 turns of engagement on the stud. This is anecdotal evidence, but I ran a 1st gen hyperblue for 20,000 miles on 17x9 ET45 Enkei RPF1 wheels with a 3mm spacer up front and had no rubbing issues either. |
The Following 2 Users Say Thank You to CZ6T For This Useful Post: | Fletch (02-06-2022), MMoore4545 (02-07-2022) |
02-15-2022, 01:35 PM | #362 |
Drives: 2022 brz limited (WR Blue)
So I'm thinking this is the setup I want to go with for stock suspension no chamber adjustment square setup.
18x8.5 +35mm Michelin Pilot Sport 4 S 245/35ZR18 will this work? I used will they fit and to my eyes it looks like it should fit but I wanted some unbiased opinions on it. |
02-15-2022, 02:27 PM | #363 | |
Drives: Ice Silver 2022 BRZ Limited
02-15-2022, 02:41 PM | #364 |
hmmmm that's interesting was that for the all around or just front or rear? I got my combo from fitment industries I haven't bought them yet but they said it was within safe margins. What was the reasoning the salesperson gave for the +45mm? Would a 10mm hub centric spacer work on it? would changing it to 40r change that? im not questioning the sales person just trying to understand as i dont know much about wheel fitment.
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
