Old 04-18-2014, 05:29 PM   #1
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
P0016 fixable without new ECU?
My first real CEL, first one was for loose gas cap.
I have read the TSB for this and it says a new ECU may be required. Just curious for those that have had this did you need a new ecu?
Reason I am asking is I am tuned/turbod and don't really want to have to get a new ecu and thus ECUtek licenses for my car.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-25-2014, 10:04 AM   #2
TemeCal
Drives: 86
What did you end up doing? I'm just curious, since you're FI now. I've supercharged my car, and am always worried about hitting this again. I've had similar errors on 3 separate occasions before I went FI. I had cam gears replaced, 3 new ECUs and several flashes/updates.
Do you know what ECU you're running? Here's the latest one I'm running (812):
http://www.ft86club.com/forums/showp...postcount=1553
TemeCal is offline   Reply With Quote
Old 04-29-2014, 08:27 AM   #3
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've just got PO016 and C1201
Dealer has checked cam gears, VVT, oil pressure valve and diagnostics on the ECU, everything is 100%
Going to change oil and check if code comes back on.
Ryan86 is offline   Reply With Quote
Old 05-24-2017, 09:13 AM   #4
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
@Mr.Jay @TemeCal @Ryan86
Any updates on what you did to resolve your personal P0016 codes? I have had this as well for a long time. I had my tuner remove the code and eventually I need to address the real problem.
blackfireball5 is offline   Reply With Quote
Old 05-25-2017, 04:45 PM   #5
G-awesome
Drives: 2015 Firestorm Scion FRS
I'm dealing with this issue now. I'm patiently waiting for a new ecu at this stage of the repairs...the damn thing is backordered and I'm getting sick and tired of clearing the code and driving in limp mode. They're gonna crack open the cam assembly this time and replace the ecu so it should fix the problem this time.
I had the current ecu updated and the cam sensors swapped and it did nothing.
G-awesome is offline   Reply With Quote
Old 05-29-2017, 09:41 PM   #6
CTB727
Drives: 2013 Subaru BRZ
I had this issue recently on my 2013 BRZ, and the dealer ended up replacing both the cam sprocket and ECU. So far so good.
CTB727 is offline   Reply With Quote
Old 01-30-2022, 12:21 AM   #7
Sebring12
Same for me. I had a P0016 and did the hot oil flush and software update recommended in the TSB and no luck. Then they replaced the ECU last month and so far so good. I currently have 56k miles on my 2013....
Sebring12 is offline   Reply With Quote
Old 02-05-2022, 07:37 PM   #8
Decep
Drives: 2013 FR-S Series 10
How much is an ECU these days with the chip shortage?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 02-06-2022, 05:15 AM   #9
jrhudson
Drives: 2016 scion frs
you can get a used one for about 100. just follow @steve99's guide on it. https://www.ft86club.com/forums/showthread.php?t=102810
jrhudson is offline   Reply With Quote
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
Fixable? somejace Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 09-22-2013 11:24 AM
Got a nail! Fixable? jbravo373 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 09-03-2013 05:28 PM
