Drives: 2018 Subaru BRZ with PP
Wiring for Valenti 4th Brake Light with 2017-2020 Stock Taillights
Hi all,
I wanted to write this up for future reference for those who have a Valenti 4th brake light. I am also writing this up for 2017-2020 stock taillights. The car used is a 2018 Subaru BRZ Limited with performance package. I wanted to have the 4th brake light look OEM and these were as close as I can get them. Also, this wiring is for U.S. cars. Not sure if other countries have similar wiring. I purchased this 4th brake light: https://www.ftspeed.com/part/htyf86r...6#.Yfx5yPXMK3I Although it says OLM, the lens says 'Valenti.' ![]() ![]() I purchased this custom harness as I didn't want to tap into the taillights and to have a cleaner wiring situation: https://www.facebook.com/marketplace...5-921671f52593 ![]() ![]() If you just wanted to tap into your taillights, that will work as well. Should still be the same connections. I decided I didn't want the flashes when the brake light is pressed so I soldered mine as Version 3 from this video: ![]() So the light comes with 4 wires: red wire by itself and black, light blue, and green in one harness. You will need to unpin the light blue wire to tap into the taillights. ![]() Once I soldered it, I tested it out by connecting the following wires: Light blue wire to PARK. Red Wire to BRAKE. No wire to GROUND. Black and green wire will plug and play to reverse harness. ![]() ![]() Here's what it looks like with soldering for Version 3 from the vid: No lights (to show what 4th brake light looks like with stock taillights): ![]() Parking lights on: ![]() Brake (no flash): ![]() Reverse lights: ![]() This diagram helped in making sure I made the correct connections. ![]() Not sure if this is the similar procedure for 2013-2016 stock taillights or even aftermarket taillights with Valentis or other 4th brake light, but feel free to chime in for what worked for you. Have fun!
| Tags |
| 4th brake light, valenti, valenti 4th brake light, wiring |
| 4th Brake Light Help for 2017-2020 BRZ Stock Taillights | juenedgi | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 02-04-2022 01:36 AM |
| HELP Wiring Valenti 4th Brake Light to 2017+ Tail Lights | ParticleMan | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-02-2021 03:10 PM |
| Wiring & Splicing Valenti Revo SB2 tail lights to Valenti fourth brake light | Ep140 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-16-2020 05:05 PM |
| Valenti reverse light/4th taillight wiring with stock MY17 taillights | Elliotw | DIY (Do-It-Yourself) Guides | 3 | 04-16-2020 09:22 PM |
| Valenti 4th Brake Light wiring for 2017 MY | wasabiseaweed | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-11-2017 02:56 PM |
