Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-01-2022, 10:32 PM   #533
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
My winter setup finally arrived.
Midnightsky is offline   Reply With Quote
The Following 2 Users Say Thank You to Midnightsky For This Useful Post:
beltax90 (02-02-2022), Stonehorsw (02-02-2022)
Old 02-02-2022, 06:28 AM   #534
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Originally Posted by suhhh View Post
went for 18x9.5 +38!
Wanted these wheels so bad but they didn't come in 5x100 bolt pattern, found out that work japan can do special order so I hopped on it asap before the price increases 2/8
I used to own those wheels and really loved them. Same spec you ordered. Work has always offered the 5x100 pattern in most of their wheels. It's just that distributors don't stock them and they are too lazy to explain in their sites that they can be ordered in custom patterns, widths and offsets. Whatever workwheelsusa.com has in their product spec sheet can be ordered.
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
Old 02-02-2022, 08:24 AM   #535
soundman98
ProCrastinationConsultant
soundman98's Avatar
any recommendations of who's willing to order those non-stock wheels?
Old 02-02-2022, 01:19 PM   #536
Raven86Project
Any Work distributor can order them. You just have to contact them if they are not listing the specs you want. I can recommend System Motorsports.
IG: raven86project
Build Thread HERE
The Following User Says Thank You to Raven86Project For This Useful Post:
soundman98 (02-02-2022)
Old 02-03-2022, 01:54 AM   #537
joemysterio
Drives: Mini
Does anyone have the courage to PPF their own car? Just noticed that xpel has pre-cut kits. If I can't find a reasonably priced shop around me, I may give it a go (front bumper) but then I think to myself... that's almost $500 I'll likely end up throwing away lol.
https://www.xpel.com/paint-protectio...ru/BRZ/Limited
joemysterio is offline   Reply With Quote
Old 02-03-2022, 03:43 PM   #538
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Originally Posted by MikeNSX2 View Post
Went to my dealership to have them register my new wheels and sensors I bought from Tirerack.
They were unable to do this, unfortunately.
I drove almost 40 minutes each way and was told they would need to have them break down the wheels and tires so that they could input the sensor #s to make them pair to my car. Was told it would cost $200+ to do this. I passed.
Hey Mike,
That's a bummer - sorry to hear.
To clarify (please correct me, I'm assuming); you purchased wheels/tire combo on Tire Rack and had Tire Rack install the TPMS sensors before shipment as part of their package, then when you put the new wheel/tire set on the car and tried to have them registered as the second TMPS set, it wouldn't; then went to your dealership and they stated they could not do it without de-tiring the wheels to look at the TMPS sensor part number - to presumably have the part number coded with the onboard sensor system?
I'm surprised - I was under the impression with the 2nd gen a second TPMS sensor set could be registered naturally but by this account the Tire Rack's sensors are not compatible with the BRZ... This should be brought up to Tire Rack, because what would the point of having them installed before shipment be if they will need to be taken out afterwards.
I did a Tire Rack bundle on the S2000 with sensors and had no issues, I had also purchased some Amazon sensors for the 911 when the battery went low on OEM; they also paired up without issue... But both of those are older cars and likely less finicky ECUs.
Re_Invention is offline   Reply With Quote
Old 02-03-2022, 04:55 PM   #539
AK2112
AK2112's Avatar
Drives: 22 BRZ
$500 and a difficulty rating of 5/5. No thanks.
Would rather save that $500 and if the front bumper gets peppered, have it resprayed in 10 years (assuming I even keep the car that long).
AK2112 is offline   Reply With Quote
The Following User Says Thank You to AK2112 For This Useful Post:
SpectreRT (02-03-2022)
Old 02-03-2022, 05:42 PM   #540
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
Originally Posted by Re_Invention View Post
Hey Mike,
You are correct in everything you said...up until the point you said "I'm surprised."
The TPMS sensors on a second set of wheels need to be registered at a Subaru dealership according to the Owner's Manual...you cannot do this at home by just mounting the new wheels/ tires and sensors and pushing the button in the glove box.
One needs the sensor ID #s, which I hopefully will be able to get at Discount Tire with their handheld scanner, and then be able to take the car to the Subaru dealership to register them to my car.
Many cars I've owned, other than my BRZ, have been really easy to have the new sensors pair with the car. The BRZ is not one of them. When I put a set of OZ wheels and tires on my Focus ST, all I needed to do was mount them on the car, and the car took care of everything as far as sensor pairing.
My Tirerack sales guys told me that Subaru is the absolute worst car manufacturer in the world regarding pairing sensors to cars.
MikeNSX2 is offline   Reply With Quote
Old 02-03-2022, 06:18 PM   #541
Brz-123
Did you try using the carista app. I clearly have the Gen 1 and have had no issues pairing sensors when mine have gone (due to low battery). Use the carista app and their blue tooth dongle, buy a pre programmed sensor for your make and model. It comes with its sensor code, just code that in using the app ( as simple as deleting the old one and typing some numbers and letters in) and Voila the new sensor is configured.
For the new one, clearly there are 2 sets of hex codes stored in ECU but worth checking Carista.
Brz-123 is offline   Reply With Quote
Old 02-03-2022, 07:31 PM   #542
MikeNSX2
This is far above my pay grade to answer this.
All I know is that the Gen 1 and the Gen 2 are totally different, Something that works for a Gen 1 does not necessarily work for a Gen 2 2022 BRZ.
Old 02-03-2022, 07:36 PM   #543
Brz-123
I thought I read somewhere it works.. I am definitely not sure about this either but this is not ECU but Dash/ OBD2 connection which remains constant irrespective.. the tyre pressure shown on Dash display come from OBD2 . Worth a try for the 20$ initial cost. If nothing it can be used for torque Pro as an obd2 to measure data.
Sent from my SM-G781B using Tapatalk
Old 02-05-2022, 04:55 AM   #544
Midnightsky
Got to playing with some CF vinyl wrap today. Still very newb at it, not perfect work, but the subtle accents fit so perfectly.
Old 02-06-2022, 01:45 AM   #545
Midnightsky
Got Betty off the nannies tonight and gave her redline, wow, 2nd gear is a gem. I learned there is 2 different ways to turn off the nannies. While pressing and holding track mode will turn off stability control, it however does NOT turn off traction control. Many probably already know this. The trick to getting both off, as soon as u start your car, press and hold the traction control button for about 5 seconds until both lights pop up on the dash. The cluster will also change to track mode. This can only be done tho immediately after starting the car as best I can tell. I had some great fun tonight, can't wait to keep pushing Betty and learning how to make her sing that magic song of awesomeness.
Old 02-08-2022, 07:49 PM   #546
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Originally Posted by CZ6T View Post
Added the GR86 premium spoiler on the car, since I'm a big fan of ducktail spoilers and I liked how well engineered the OEM one is.
I think it looks pretty good, and the paint match looks close. I can't tell if it's slightly more white or if my car is just that dirty already.
Did you end up drilling the trunk and using the factory bolts? I'm tempted to try this, sans the factory bolts and drilling.
Panda Grahams is offline   Reply With Quote
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 11:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 03:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 11:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 02:16 AM
