Old 01-28-2022, 08:53 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Exclamation SB21-056-2 BRZ MY22 - Countermeasures against Knocking and/or DTC P030x on FB2.0L DI
Repair Procedure Correction/Addition:
FB2.0L DI engines
Details of Symptom, Cause:
Internal wear of the needle flange in the Injector makes the fuel mixture leaner,
resulting in vibration and/or misfire of the engine.
DTC P219A - D <AIR-FUEL RATIO IMBALANCE> can also be set.
Trap63 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trap63 For This Useful Post:
blsfrs (01-28-2022), sato (01-28-2022), SpectreRT (01-28-2022)
Old 01-28-2022, 04:54 PM   #2
chipmunk
Drives: _
FB2.0....? I thought this was FA24...
chipmunk is offline   Reply With Quote
Old 01-28-2022, 10:18 PM   #3
jflogerzi
jflogerzi's Avatar
the revision added the BRZ. Before that it was all 2.0DI engines
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Trap63 (01-29-2022)
Funny question - BRZ MY22 export trade Trap63 BRZ Second-Gen (2022+) — General Topics 7 01-23-2022 12:33 AM
Funny question - BRZ MY22 export trade Trap63 GR86 General Topics (2nd Gen 2022+ Toyota 86) 0 01-21-2022 04:50 PM
Is this rod knocking?? msaikhan Issues | Warranty | Recalls / TSB 14 03-08-2019 09:39 PM
More knocking, now onto my coilovers.. VincentN Issues | Warranty | Recalls / TSB 2 12-01-2017 07:45 PM
Laser Countermeasures Mpowered Electronics | Audio | NAV | Infotainment 2 02-24-2013 02:44 AM
