Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-27-2022, 01:33 PM   #491
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Originally Posted by suhhh View Post
Yeah, gonna have to really figure out what specs I want to run. This is my daily driver and will be bringing it to the track to slide around in, unsure if I want to do a 245/35 square summer tire setup and buy burner rear wheels or run 225/40 all seasons w stretch all around for some easier time sliding
I’ve been sliding my car a bit and I think it would probably be smarter to just getting a burner set. 225/40 is more tire than I’d personally run, but you could just run 50 psi. I’d prob do a 215 or so at a nice 40-45psi. Also, don’t forget that running 18s is gonna rack up a nice tire bill quick. Lastly, I believe the last gen cars really hate having different radius wheel/tire setups and will go into limp mode so that is also something worth checking.
Kona61 is offline   Reply With Quote
Old 01-27-2022, 02:48 PM   #492
jvincent
jvincent's Avatar
Phone mount
It warmed up enough to install my phone mount. There's exactly enough room for the adhesive pad for this mount to fit just on the inside of the console.
https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
The plate on my phone case is on the bottom to support wireless charging so when the phone is attached it's just perfect and the USB cable will still fit.
Old 01-27-2022, 03:11 PM   #493
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Copy that, thank you for the advice I appreciate it man
I'm just getting into sliding with this car, I've been a long time drifter fan and have tons of sim rig experience so I hope to get a lot of seat time this summer so I can really get a feel for it. Doing as much research as I can now
I was debating on just fitting the oem 215/40 tires but it is quite a bit of stretch, but I heard it's better to initiate and keep control
I have a current set of 16 inch steelies, may just use them even though it'll be ugly asf haha.
Didn't know about the limp mode issues, would pulling ABS help with that or is that a separate issue? Wonder why it does that
suhhh is offline   Reply With Quote
Old 01-27-2022, 05:10 PM   #494
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Yea, I’d say 215 whatever’s on a 17x7-7.5 or so would be cheapest and best. This car has a lot more power but it definitely is more of a momentum car than something like a 370Z.
I don’t recall exactly on the last part. I never actually bought a 1st gen but I think people pulled one of the wheel speed sensors or something, which would make sense.
Old 01-27-2022, 06:49 PM   #495
jongers
Drives: 19 86, 22 BRZ
Finally got my suspension components installed (coils + rlca) and aligned. ~1 finger gap w/ -2.6 front, -3 rear.
Fitment is definitely a bit tight with 18x9.5 +40 on 255/35. Rear inner fenders were shaved/cut previously. Havent noticed any major rubbing issues yet, but I've only driven like 20 miles.
jongers is offline   Reply With Quote
Old 01-27-2022, 10:11 PM   #496
Jucostud
Rookie
Jucostud's Avatar
Drives: '22 BRZ Premium MT6
Got my tires mounted. Will install wheels when my MCS coilovers come in. Any day now.
Jucostud is offline   Reply With Quote
Old 01-27-2022, 11:35 PM   #497
eyeballs
Drives: '22 BRZ
Swapped out the exhaust tips for the JDM version. Hopefully it won't be too long before some properly developed header options are available for the 2nd gen.
eyeballs is offline   Reply With Quote
Old 01-28-2022, 10:30 AM   #498
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
If anyone ever installs a phone holder that attaches to the floor/rail like this one: https://www.amazon.com/gp/product/B0...ustomerReviews
show pics or tag me. A friend had one in an FR-S that I thought looked super clean, and I was curious if one can be used in the new cars.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 01-28-2022, 11:24 AM   #499
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
Went out for a ride today, and what a headwind I encountered!
Shub Deetle is offline   Reply With Quote
Old 01-28-2022, 12:18 PM   #500
joemysterio
Drives: Mini
Very interesting but with such a long neck, I'd be worried of too much movement or vibration without some sort of stabilizer closer to where the phone would be. I have something significantly shorter but it still vibrates too much when my car is on.
joemysterio is offline   Reply With Quote
Old 01-28-2022, 04:37 PM   #501
Daedex
That One Guy
Daedex's Avatar
Thats weird. From what I remember (this was 2017), it didnt vibrate at all or move at all except when my knee hit it (he put it on the passenger side).
That might be more due to the length of the chord absorbing vibrations maybe? Idk. But I wanted to try something similar.
Old 01-28-2022, 05:32 PM   #502
SlowTime
Drives: 2009 MX-5
Specs on those rims and tires?
SlowTime is offline   Reply With Quote
Old 01-28-2022, 07:03 PM   #503
joemysterio
Drives: Mini
I'm checking out my car and phone mount... Looking at it closer again (I don't really drive much anymore since I WFH), this is likely an isolated issue for me, so my last post can probably be disregarded.
I've upgraded my motor mounts so there's additional vibration in my car, and my phone mount connects to the speedometer gauge. The speedometer is not super snug/fixed in, not sure if the screws are loose or what but when I hold it down, the vibration mostly stops. This is what my current set up is, very short arms in comparison: https://imgur.com/a/ya14h5s
So yeah, likely isolated to just me.
Old 01-29-2022, 12:45 AM   #504
Jucostud
Rookie
Jucostud's Avatar
17x9+45 with 245/40/17 falken rt660's. I'll be running a 10mm spacer on the front.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
