Old 07-31-2012, 12:32 AM   #29
Dimman
Kuruma Otaku
Dimman's Avatar
^ So basically if the exhaust is very thick-walled, rigid and water cooled, aluminum will be perfect?
Because titanium.
Old 07-31-2012, 12:40 AM   #30
OrbitalEllipses
Drives: Attitude
I was about to ask what manifolds cast into heads have to do with thin ass piping.
Old 07-31-2012, 12:46 AM   #31
Dimman
Kuruma Otaku
Dimman's Avatar
It is interesting that manufacturers are moving in that direction, but I suspect it has a bit to do with reducing the amount of assembly time and parts. Could also be used to control EGTs better so they don't overcook the cats, too.
Because titanium.
Old 07-31-2012, 05:40 AM   #32
noAE86
Drives: ae86, etc..
this is starting to remind me of the arguments when plastic intake manifolds where coming into production,
noAE86 is offline   Reply With Quote
Old 07-31-2012, 11:06 AM   #33
arghx7
Drives: car
The Civic and Chrysler V6 engines are not using water cooled manifolds.
The water cooling is for turbo engines so that they don't have to enrich the mixture nearly as much to keep cat temps down. Any way you look at it, it's still an aluminum exhaust manifold whether it's bolted or casted to the head.
Old 07-31-2012, 11:17 AM   #34
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Well since they are already making a casting, anything you can combine in to it saves tooling and production cost as well.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 07-31-2012, 11:18 AM   #35
Dimman
Kuruma Otaku
Dimman's Avatar
I know you know your stuff and that manifold/extended head is interesting. But I was just presenting things a little differently, since I have this image of some noobs welding up a bunch of aluminum intercooler piping as an exhaust and wondering why it fails 6 months later.
Because titanium.
Old 07-31-2012, 11:25 AM   #36
HunterGreene
Hail Magnet
HunterGreene's Avatar
Comparing manifolds to cat-back/axle-back exhaust systems is like comparing apples to oranges. They are constructed different, as Dimman said.
And whoever said it was correct--304 stainless (which is the standard in the industry) is the best price/weight/durability currently for exhaust systems.
Old 07-31-2012, 11:32 AM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-31-2012, 11:41 AM   #38
thermobox
Drives: 16 Impreza 5dr CWP
But c'mon guys. We can combine 4 turbo cylinder heads and two non-turbo cylinder heads to make an extremely light weight exhaust? Whiskey Tango Foxtrot? What the hell is going on inside this thread?
If Aluminum was the way to go, wouldn't all of the aftermarket Mfrs already be doing it? They don't make it because it makes no sense.
Yes, you can use Aluminum all over a car in high heat applications, just not the actual piping of an exhaust.
thermobox is offline   Reply With Quote
Old 07-31-2012, 12:01 PM   #39
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
This would all make sense if the bottom line wasn't "that is too loud for my local track."
Aluminum axleback is about a 2lb savings over a 304 single exit. Factory midpipe is 18ga (thin) stainless. We might take a crack at an aluminum midpipe. But thus far we haven't found good enough pricing on Ti 2.5" tubing to make it worthwhile.
And from what I have read in the metallurgy literature, bonding is a better solution than welding in most cases. Not sure how the high strength and fatigue resilient epoxies will withstand oxidizers and temperature like found in exhaust gas. Same can be said of aluminum in general. Kinda tough to anodize a 7' long pipe. But if it was a known seasonal consumable, that'd be a different story.
J
Jason@Nameless is offline   Reply With Quote
Old 07-31-2012, 02:41 PM   #40
serialk11r
Drives: '06 AM V8V Coupe
J
How about not fixed at all? Silicone seals (good up to 500C or something) and some kind of slip fit thing? And then for mounting maybe add a structural support extrusion of some sort, held onto the pipe with silicone as well.
Old 07-31-2012, 03:08 PM   #41
Motordyne
Motordyne
Motordyne's Avatar
Drives: Nissan Z & Infiniti G
LOL! That's awesome!
Motordyne is offline   Reply With Quote
Old 08-01-2012, 02:18 PM   #42
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Titanium or bust!
JDLAutoDesign is offline   Reply With Quote
BRZ STI front under spoiler and 17" aluminum wheels released in Japan yajin BRZ First-Gen (2012+) — General Topics 99 05-31-2012 07:09 PM
Steel Vs Aluminum in the FT86 blur Scion FR-S / Toyota 86 GT86 General Forum 72 06-08-2011 04:35 AM
