Old 01-24-2022, 09:23 PM   #1
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Quick question before I install these RCE SS1
Ordered the Superstreet 1 coils from Racecomp and upon opening I noticed both the front coils have some sort of weird thing going on with the camber plates but as a disclaimer I’ve never held coils ever in my life as these are my first time buying so not sure why the bolts don’t sit flush the camber plates. But looking at the unboxing of them by QueenBRZ on YouTube hers seem to sit pretty flush. I’m assuming all I gotta do is unscrew those 4 screws and it’ll fix it and I should be fine but I just need a good quality check before I put them in Saturday..also only got one damping knob not sure I’m im supposed to get two as I never ordered from them. But all around the quality of these feel great!
blakkoutdarko is offline   Reply With Quote
Old 01-25-2022, 02:40 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If you are talking about the 4 plate adjustment bolts those don't have to be flush, just tight.
Pretty sure if you RTFM it will explain everything.
At least I would hope so.
As for the missing adjuster. Email them and ask.
The Following User Says Thank You to x808drifter For This Useful Post:
blakkoutdarko (01-25-2022)
Old 01-25-2022, 06:50 AM   #3
blakkoutdarko
No I’m asking about that middle bolt in the center of the 4 bolts it’s like off centered
The Following User Says Thank You to blakkoutdarko For This Useful Post:
x808drifter (01-26-2022)
Old 01-25-2022, 11:46 AM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Its bolted to the ball joint that sits below the top plate. If you move the top hat, it should rotate around the nut. It's part of the design. What is the brand/model you are comparing them to? Not all coilovers are designed the same.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
blakkoutdarko (01-25-2022), x808drifter (01-26-2022)
Old 01-25-2022, 12:05 PM   #5
Easy @Racecomp Engineering
BigTuna (01-25-2022), blakkoutdarko (01-25-2022), Racecomp Engineering (01-25-2022)
Old 01-25-2022, 12:26 PM   #6
Hard to see in the pics but looks like the camber plate is just pivoted to 1 side (which it's designed to do).
We only include 1 adjustment knob...keep it in your glovebox.
Give us a call anytime if you have any questions at all.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
BigTuna (01-25-2022), blakkoutdarko (01-25-2022), Tcoat (01-25-2022), x808drifter (01-26-2022)
Old 01-25-2022, 07:15 PM   #7
blakkoutdarko
- Andrew
Ok good to hear, thanks Andrew
Racecomp Engineering (01-26-2022)
Alignment Shop in SD and quick question question JohnTran619 Southern California 5 11-21-2018 02:40 PM
Quick question about exhaust install Karl07 Engine, Exhaust, Transmission 14 12-30-2016 04:10 AM
TRD Quick Shifter Bad Install? iNcontroL Engine, Exhaust, Transmission 3 12-29-2015 07:06 PM
Quick release install help rixter145 Northwest 0 10-01-2015 03:12 AM
Quick Question about Doing coilover install Xdragonxb0i DIY (Do-It-Yourself) Guides 3 05-31-2013 03:14 PM
