go_a_way1, MisterSheep
Old 01-20-2022, 08:29 AM   #23479
Little Samurai
Ulli
Little Samurai's Avatar
Drives: Toyota GT86
Valves Control on the FA20 Engine
Little Samurai is offline   Reply With Quote
The Following User Says Thank You to Little Samurai For This Useful Post:
Cephas (01-24-2022)
Old 01-20-2022, 09:27 AM   #23480
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I hear that you can adjust the clearance by adding extra sealant.
The Following 8 Users Say Thank You to blsfrs For This Useful Post:
alex87f (01-20-2022), Dadhawk (01-20-2022), DarkPira7e (04-29-2022), Jdmjunkie (01-20-2022), MJones_RB (01-26-2022), NoHaveMSG (01-22-2022), soundman98 (01-20-2022), Ultramaroon (01-20-2022)
Old 01-22-2022, 05:46 PM   #23481
Little Samurai
Ulli
Drives: Toyota GT86
we set the valves specifically to a tenth so that the engine runs smoothly. many think it has hydraulic valve lifters but that is wrong. The valves have to be adjusted every 60,000 km
Wally86 (01-22-2022)
Old 01-22-2022, 07:32 PM   #23482
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
16's really look good on these cars!
The FA20 has shims??
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 01-23-2022, 11:19 AM   #23483
blsfrs
blsfrs's Avatar
Track or street driving? Most of us aren't going pull our engines to adjust the valves at 40,000 miles.
The Following 4 Users Say Thank You to blsfrs For This Useful Post:
Jdmjunkie (01-23-2022), NoHaveMSG (01-23-2022), Wally86 (01-24-2022), WNDSRFR (01-23-2022)
Old 01-23-2022, 02:41 PM   #23484
WNDSRFR
Drives: FR-S,GTI
So, you're saying I should have dropped my engine and adjusted the valves 5 times by now? Even though there's nothing wrong with them?
Damn, it's a big enough PITA just to drop the tranny every 100,000 miles to replace the TOB!
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
blsfrs (01-23-2022), Jdmjunkie (01-23-2022), soundman98 (01-23-2022)
Old 01-26-2022, 10:47 AM   #23485
Compelica
Compelica's Avatar
Drives: 86 GT
Did an autocross and gymkhana practice session today. Far more engaging than a track day - I should have started way sooner.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 01-26-2022, 12:43 PM   #23486
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Bucket shim has very little wear, especially when a roller rocker is also incorporated. You may see some minor lash changes in the first service interval, not necessarily large enough to require adjustment. Further intervals typically see very little change if any. The rocker pivot sits in a galley and is acted on by pressurized oil. It is not acting as a hydraulic lash adjuster but probably does take up some play while the engine is running.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (01-26-2022), Wally86 (01-26-2022)
Old 01-27-2022, 10:11 AM   #23487
blsfrs
blsfrs's Avatar
My understanding is the long term problem with lash is the loss of lash due to valve recession, not an increase due to wear and tear that you might see in a push rod engine.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 12:51 PM   #23488
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In general this has been my experience. The worst is SOHC with tappet follower. Those always get out of spec and end up all over the place. Not a common in cars though, usually just air cooled motorcycles.
blsfrs (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 02:54 PM   #23489
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
One thing I learned about valve lash adjustment, from my GS-R days, is that getting them into spec can help you pass SMOG.
MJones_RB is offline   Reply With Quote
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
blsfrs (01-28-2022), soundman98 (01-27-2022)
Old 01-27-2022, 03:06 PM   #23490
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I could see a tight valve cause issues on an emission test.
blsfrs (01-28-2022), MJones_RB (01-28-2022)
Old 01-30-2022, 06:23 PM   #23491
DarkSunrise
DarkSunrise's Avatar
Finally washed it! Unfortunately was a machine wash since my kid loves them (the first the car’s ever seen)but I think it turned out pretty decent. A few marks left (melted rubber streaks from the track) but I’ll clean those off later.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
Busybee (01-30-2022), MJones_RB (01-31-2022), NoHaveMSG (01-30-2022)
Old 01-30-2022, 07:04 PM   #23492
soundman98
ProCrastinationConsultant
soundman98's Avatar
stared at it longingly while it sits in the garage. said screw it, went inside to grab the keys, and it started snowing...
The Following 7 Users Say Thank You to soundman98 For This Useful Post:
7 skulls (02-03-2022), Busybee (01-30-2022), Jdmjunkie (01-30-2022), NoHaveMSG (01-31-2022), Stephen W. (01-30-2022), The Red One (01-31-2022), Ultramaroon (01-31-2022)
