Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-16-2022, 05:54 PM   #365
jvincent
jvincent's Avatar
Installed my front license plate today using the JDM to US adapter from Amazon.
Old 01-16-2022, 06:23 PM   #366
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
Originally Posted by Midnightsky View Post
Hockey pucks work in a pinch too lol #IAMCANADIAN
Same here - cheap at Canadian Tire, and last for quite a few uses.
Don't go for any other densities other than standard though. I tried some denser hockey pucks and they were too brittle, especially at -20C.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
The Following User Says Thank You to 22 BRZ For This Useful Post:
Midnightsky (01-16-2022)
Old 01-17-2022, 03:18 AM   #367
tenderization
Drives: 88 RX-7, 2022 BRZ
Late post-breakin oil change @ 1683 miles
Second-guessed myself a few times reading the classic subaru dipstick, but 5 quarts ~6 ounces seems to do it when using an extractor and changing the filter.
Please ignore the xpel tracwrap as I'm waiting for PPF.
tenderization is offline   Reply With Quote
Old 01-17-2022, 03:55 AM   #368
Brz-123
Excellent.
Hope you changed the oil filter too as any metal shavings from new will be caught by it. What oil brand did you use?
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 01-17-2022, 12:41 PM   #369
otter
Drives: 22 BRZ
It'd be nice to see if someone could come up with a set of jacking rails this car (and any car, really). Really popular mod on S550 Mustangs. It's a reinforced bar that bolts under the car just inside of the pinch weld - allows you to place the jack anywhere you'd like on the side of the car, including the center, and raise it without damaging any pinch welds. Was really nice to jack from the center, lift the whole side of the car evenly, then place both the front and rear stands at once. Saved me some time swapping wheels at the track or autox.
https://www.steeda.com/steeda-s550-m...-555-5205.html
otter is offline   Reply With Quote
The Following User Says Thank You to otter For This Useful Post:
Midnightsky (01-17-2022)
Old 01-17-2022, 12:57 PM   #370
jvincent
jvincent's Avatar
For track changes why not just use the front/back jack points (frame / diff) and do the fronts / rears at the same time?
Unless you need the whole car in the air for some underbody work it's much faster that way. That's how I do my brake pad changes for the track.
The Following User Says Thank You to jvincent For This Useful Post:
Ohio Enthusiast (01-17-2022)
Old 01-17-2022, 01:03 PM   #371
otter
Drives: 22 BRZ
Don't have my BRZ yet so didn't know it had those jacking points. Past few cars I've had have lacked front/rear points, or were so low that you couldn't get to them, so I've become accustomed to only having the pinch welds as a viable option.
Old 01-17-2022, 01:07 PM   #372
jvincent
jvincent's Avatar
You'll need a low profile jack for the front/rear points but other than that they're super convenient.
Old 01-17-2022, 10:56 PM   #373
cpierr03
Drives: 2022 BRZ
I installed a Viofo A129 Pro Duo dashcam
Rear video
Front video
cpierr03 is offline   Reply With Quote
Old 01-18-2022, 12:27 AM   #374
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Rear video
Front video
What did you use to get 5V from the headliner wiring?
Old 01-18-2022, 01:02 AM   #375
cpierr03
Drives: 2022 BRZ
I didn't. Power is routed from the glove box, up the side pillar, through the headliner, and routed through the same cable guide for the home-link mirror.
I have a power kit to wire in both constant power/ignition switch for parking mode which I'll get around to at some point.
The Following 2 Users Say Thank You to cpierr03 For This Useful Post:
Midnightsky (01-18-2022), Yoshoobaroo (01-18-2022)
Old 01-18-2022, 01:45 AM   #376
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Rear video
Front video
I need to buy one of these someday. Looking like a solid install.
Midnightsky is offline   Reply With Quote
Old 01-18-2022, 02:12 AM   #377
tenderization
Originally Posted by Brz-123 View Post
Excellent.
Changed w/ OEM Filter and OEM 0W-20. Have seen more track-minded folks using a heavier weight so considering that next time.
Old 01-18-2022, 09:10 AM   #378
Yoshoobaroo
TRACKBREAD
Ah. I couldn’t immediately see how to take the cable guide off, didn’t want to break it. My usb connector is too big to fit through the hole. Any tips?
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 11:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 03:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 11:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 02:16 AM
