#15 | |
ProCrastinationConsultant
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | humfrz (01-06-2022), x808drifter (01-07-2022) |
#16 | |
I was "jest ah messen wich" ol Ultramaroon -
#17 |
Drives: car
I've had tapping on startup once, it was the day after my car had been picked up J02 valve spring recall (3 years ago) and the fuel in the tank had been sitting for a month. It was also the middle of July in a 100+*F. I think it was a fueling issue for one reason or another but given it was right after the recall service, can't throw that out.
#18 |
Drives: Toyota GT86 2012
Hello again guys.
After recording each start for ~10 days, it finally happened again (after leaving it outside for a day and a half), and I was able to capture it : It starts at around 15s and is quite loud (before that there is the sound of rain). No sure how to describe it, kinda metallic vibration/creaking? Last edited by Youx; 01-16-2022 at 08:53 AM. |
| The Following User Says Thank You to Youx For This Useful Post: | Ultramaroon (01-16-2022) |
#20 |
Drives: Subaru BRZ
#21 |
Drives: Subaru BRZ
And then for the computer nerds on the forum:
Excuse the quality, it is Microsoft after all... |
#22 |
I am certain that it's not engine mechanical. Other than that, I could make some wild guesses. It does sound like a metallic creak.
#23 |
Thanks for the feedback. That would be quite a relief
Where would you look at first? I was thinking loud like that it could come from somewhere along the exhaust line, like something loose or a catalytic converter starting to die? (I know from experience catalytic converters can make a metallic rattle when they start to break, although 80k km seems a bit early). Bottom inspection first? I’ll keep in mind the oil pressure check too, but for now I don’t have the equipment… |
#24 |
Drives: 2013 frs base
Can you shoot another video looking under the hood (bonnet). Maybe look specifically at the belt tensioner. Also is the sound coming more from one side of the engine or the other.
#25 |
Drives: 2013 WRB BRZ
My first thought was exhaust heat shield rattling or touching part of the frame.
| The Following 2 Users Say Thank You to BigTuna For This Useful Post: | mswbrz (03-30-2022), Ultramaroon (01-17-2022) |
#26 | |
I’ll get the car back in 2 weeks, so I’ll do another video then (and maybe get someone to start it while I film/listen from outside). I should also have access to a pit then, so I’ll look at the visible exhaust parts. Thanks! |
| The Following 2 Users Say Thank You to Youx For This Useful Post: | blsfrs (01-17-2022), Ultramaroon (01-17-2022) |
#27 |
#28 | |
It's an odd one! Maybe a loose engine support. It's loud!
| Transmission Noise in Neutral @ Cold Start | Jackal84 | Issues | Warranty | Recalls / TSB | 57 | 03-01-2021 03:21 PM |
| Cold start up popping noise | Weeber | Issues | Warranty | Recalls / TSB | 51 | 09-23-2016 12:54 PM |
| Perrin CBE crackling noise during cold start | tracerit | Engine, Exhaust, Transmission | 8 | 02-26-2015 03:43 PM |
| Rubbing noise on cold start only in reverse? | brsaresmgs | Issues | Warranty | Recalls / TSB | 2 | 01-18-2015 07:15 PM |
| Cold Start Clunk Noise | Luckrider | Issues | Warranty | Recalls / TSB | 6 | 11-28-2013 05:02 PM |
