| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2014 FR-S MT Monogram
What engine oil do you guys run?
I'm on an OFT stage 2+ e85 tune as of yesterday and I heard that you should change your oil to an e85 compatible oil. I also have read about a lot of people moving to a slightly thicker oil than stock as it's better for the engine when driving hard. Does anyone have any recommendations for what oil I should run knowing this? I do a lot of very hard driving and my car only has about 3k miles on the block and I wanna make sure I maintain it and don't blow it. Thanks for any suggestions
#2 |
Drives: '13 Whiteout
Any good synthetic will work. 5-30 is a good one. I run 0-20 at the direction of my engine builder and IAG who supplied the short block. Their warranty is void if 0-20 wasn’t used.
#3 |
#5 |
#6 |
#7 |
#8 |
The only correct answer to what oil to use is “NEW”. With E85 I would change oil more often.
| The Following 3 Users Say Thank You to Grady For This Useful Post: |
#9 |
Drives: SWP BRZ
i am pretty sure tons of people still stick with 0w-20 even using E85. educate us what will go wrong if we stick with 0w-20
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | Yoshoobaroo (01-17-2022) |
#10 |
It’s not the viscosity. Lol. It’s the chemical composition.
#11 |
#12 |
#13 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Canola, but Avocado works in a pinch. Jokes aside, Motul Xcess 8100 5w30. Track driven summer car on Costco 91 or Petro 94.
#14 |
| Brief engine knock/cold engine/first couple accelerations@2.8-3krpm | Reyanth | Issues | Warranty | Recalls / TSB | 5 | 11-15-2020 02:32 PM |
| Need some advice on engine guys! | dsteezy86 | Northern California | 23 | 01-19-2017 07:33 AM |
| BC Coilover settings you guys guys ride on | g0lden | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-06-2014 06:56 PM |
| Do you guys have the dealership to change out your engine oil? | JS + BRZ | Southern California | 11 | 01-04-2014 12:23 AM |
