Old 01-15-2022, 03:59 PM   #15
toughguy39
toughguy39's Avatar
Drives: WRB Turbo Brz
Originally Posted by Jdmjunkie View Post
Either get the MCS traction mod or adjustable traction arms to reduce rear anti-squat. The geometry of our rear suspension is off of the WRX so it is setup for awd not rwd. By tuning out the anto-squat you induce more rearward weight transfer giving you more grip. Also get better tires.
By mcs, do you mean mca? If so, confirm it is this please:
https://mcasuspension.com/gt86-and-brz-traction-mod/
toughguy39 is offline   Reply With Quote
Old 01-15-2022, 04:02 PM   #16
toughguy39
toughguy39's Avatar
Originally Posted by DougKelly20 View Post
No I mean I'm 5 clicks from full soft. Still way stiffer than stock. Would not recommend using much different setting front and rear unless you are really testing how it corners that way...
Sheeeeeesh yeah definitely wasn't on the same page there. However I did try it at that setting when I took a road trip and it actually felt softer than stock. So I guess I will have to do some playing around with those dials. Thanks for the help.
Old 01-15-2022, 04:03 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yeah you have all season tires, they’re meant to get the kids to soccer practice, not put power down.
Continental extreme contract sport or Michelin ps4s will be a big step up if you want a tire that lasts ~20k miles for normal driving. If you’re ok replacement more often then that (5k-10k miles) Yokohama A052 or BFG Rival S 1.5 have good longitudinal grip.
Get summer tires, it’s Texas, if there’s snow on the ground your work likely won’t have power anyway.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Capt Spaulding (01-17-2022), jeepmor (01-23-2022)
Old 01-15-2022, 04:08 PM   #18
toughguy39
toughguy39's Avatar
For my next set of tires, should I keep the front 225s and the rear 255s? That's what the tire shop said would be best so that's what I went with. Would like to hear what y'all have to say.
Old 01-15-2022, 04:19 PM   #19
strat61caster
Makes sense for gas mileage and drag racing I suppose. Square tires mean you can rotate them and spread the wear so they last longer it’ll handle better if you stumble across a corner. On 8.5 I’d stick with 245/40/17 but you do you.
ineedyourdiddly
Old 01-15-2022, 04:27 PM   #20
DougKelly20
Drives: Legacy 3.6R
Lol sorry guys I thought I was responding to the WRX forum...Tapatalk notification brought me here....doesn't negate anything I said other than the weight and perception of softness that I referenced. Once you suggested a staggered setup I realized I was lost.
Still before you go swapping a ton of shit try lowering your tire PSI and shock settings.
DougKelly20 is offline   Reply With Quote
The Following User Says Thank You to DougKelly20 For This Useful Post:
strat61caster (01-15-2022)
Old 01-15-2022, 05:31 PM   #21
Jdmjunkie
Drives: Scion FR-S 10 Series
Yes that is the part I was referencing. Sorry for the confusion.
Jdmjunkie is offline   Reply With Quote
Old 01-21-2022, 10:49 AM   #22
SCFD
Are we talking about straight-line grip only? I'm not sure if anybody else has tried it but the Mickey Thompson ET Street comes in a 275/40R17 but the tire will be 1" taller (26" vs 25" diameter).
SCFD is offline   Reply With Quote
Old 01-21-2022, 07:03 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stiff suspension does not equal grip.
NoHaveMSG is online now   Reply With Quote
Old 01-23-2022, 05:40 PM   #24
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Sounds like someone needs a day playing in the twisties to dial in the coils. Or an auto cross day where the clock is in play too.
I'll second the all seasons tires are weak. I run them in the winter in the PNW. After running Pilot PS4s or Yoko Advan AOD8s in the summer time, all seasons will always disappoint you. There's no way around it.
And as stated stiffer suspension isn't the answer. A work colleague was really into autox when he had his FRS. He went back to the OEM sway bars because his times were better. He said the stiffer ones felt better in the corners and stayed flatter, but they hurt his times.
Just an example that it's not always the "feel" that makes you faster, its testing and finding it. Testing like this is hard as someone, much like myself, that doesn't go out to autox and such. I just commute and drive the twisty roads once in a while. Hard to time test on public roads.
jeepmor is offline   Reply With Quote
Need advice on how to maximize my factory warranty moda3 Issues | Warranty | Recalls / TSB 12 05-17-2020 10:29 PM
WTB: NYC/NJ ARK GRIP ChaosTheSlayer Want-To-Buy Requests 0 12-05-2016 11:07 PM
WTB ark grip or dts Ayo_narith Want-To-Buy Requests 0 11-14-2015 12:17 PM
The Different between "Gain Grip by Width" & "Gain Grip by Compound"? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 05-03-2014 03:26 AM
grip? pr086 Scion FR-S / Toyota 86 GT86 General Forum 16 12-21-2012 10:36 PM
