Old 01-14-2022, 12:58 PM   #715
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
Ok. I'm in the middle of doing that right now. I just figured out where it hitting & its no where close to the whole. So I'm going to make my own
hedtrip is offline   Reply With Quote
Old 01-14-2022, 02:16 PM   #716
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by hedtrip View Post
So did anyone find a Fix for the dip stick hitting the baffle? Diff stick? trim it? drill a hole in the baffle?
I made my own hole. Pictures are in my build thread in this subforum. Regardless of the pan size, the dipstick should always be accurate, so I wanted it functional. If it just bends against the side of the baffle then it isn’t working as a dipstick and is just a plug for the valve cover. At that point, might as well trim it shorter than messing with snaking it in. I say cut a hole, but just make sure you clean it well.
Old 01-14-2022, 04:35 PM   #717
hedtrip
hedtrip's Avatar
Yeah thats what i ended up doing. I most of missed the pics when i was looking for it.
The dip stick goes in like butter now.
The Following User Says Thank You to hedtrip For This Useful Post:
Irace86.2.0 (01-14-2022)
Old 01-14-2022, 08:04 PM   #718
Irace86.2.0
Originally Posted by captain awesome View Post
That sounds about right but I'm not near my notes until this evening. I think it pulls up as DPO1 in the Haltech dropdown but it's been a minute since I've looked.
I totally blanked that I could probably check the other pins in the AC2 plug for spots to attach the EBC. I’ll have to check the wiring diagram.
Old 01-14-2022, 08:47 PM   #719
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
IIRC there was only one DPO spot left available for use.
captain awesome is offline   Reply With Quote
Old 01-14-2022, 10:09 PM   #720
Irace86.2.0
Yes, 18 for the DPO, but I’m talking about using the AC2 connector for power and ground. I was going to try to do two lines sharing the power and ground for flex fuel and for EBC, but I’m thinking now that there might be another power and ground available in that connector since it has 8 pins.
Kpower is using 1, 2 and three for the power, ground and signal wire, respectively. I will need to figure out if another plug is power and ground.
Old 01-14-2022, 10:37 PM   #721
captain awesome
Wears Pants
Ah, sorry I musta glossed over that. Biggest issue is whether it’s carried through the jumper board from Kpower and where it would end up on the other side.
Old 01-14-2022, 11:47 PM   #722
Irace86.2.0
That’s true. I didn’t think of that.
Old 01-15-2022, 09:43 PM   #723
Irace86.2.0
I think I’m just going to wire up the EBC using some interior switchable 12v source instead of going off the AC2 connector. Just saying.
Old 01-20-2022, 04:53 PM   #724
hedtrip
hedtrip's Avatar
So I have been doing a Step by step install videos for the kit. What are some none obvious things to
Look for? Or things you wish you would of known ahead of time?
Or just command issues?
I already have the
oil dip stick &
Engine mount hitting cast.
Old 01-20-2022, 05:05 PM   #725
captain awesome
Wears Pants
I already have the
oil dip stick &
Trans tunnel clearance. I and at least one other that I know of didn't make enough room initially since the photos in the instruction aren't really that helpful.
Pretty sure there was only one person that had issues with the oil drain plug being too close to the sub-frame but worth checking on your initial install.
Oil pan flange had too much material where the A/C bracket wants to be.
Don't know how many others had issues but the calibration for the oil temp sensor was way off in the base map provided for the Haltech.
Hood to valve cover clearance. IF the webbing structure of the hood has let go of it's bonding agent then it pushes against the corner of the valve cover. I just ground away a notch in the webbing and moved on with my life. A better man would have glued it back.
There's a small bracket included with the wiring harness but no instructions on what it's for. Supposedly it's to help tidy up everything by the starter so I think that's worth figuring out and mentioning.
Gas gauge issues have been a current issue that I don't think will get fixed anytime soon. I still register a hair over a 1/4 tank with only 2 gallons left.
I'm sure there's something I'm missing but I think that covers most of it?
Rolled just over 1700 miles on my swap so far. Well worth it.
The Following 3 Users Say Thank You to captain awesome For This Useful Post:
hedtrip (01-20-2022), RedReplicant (01-21-2022), venenon (01-20-2022)
Old 01-20-2022, 06:35 PM   #726
hedtrip
hedtrip's Avatar
Thanks. That is a good list of things to look out for.
Old 01-20-2022, 07:12 PM   #727
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The fuel level sensor seems to be on the passenger side, so if the driver's side is empty where the fuel pump is located then the fuel will read whatever it has, which may be about a quarter tank. The one problem with this theory is that the fuel level at 1/4 tank, but just measured on one side, is only 1/8 tank for the whole tank, yet that doesn't jive with the amount of fuel I put in the tank.
There is a sender on the fuel basket on the driver side as well as on the passenger side tank. I only know since I am working on running two fuel baskets with two pumps and I have an extra basket on my bench.
Irace86.2.0 (01-21-2022)
Old 01-21-2022, 01:58 AM   #728
Irace86.2.0
That just looks like a pair of baskets with two fuel level sensors, and one has a fuel pump and the other has a line, but with only two wires going to the passenger basket for the level sensor, it doesn’t appear to have its own crossover pump. You are saying there is a secondary pump?
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
