Old 07-31-2012, 10:30 AM   #43
MiguelAE86
Drives: NB Miata
WE DO BIG THINGS
MiguelAE86 is offline
Old 07-31-2012, 10:38 AM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Hanzo View Post
Sometimes it's better to have some restriction to increase the speed of flow. It's like if you pinch the tip of a water hose the water flows faster.
Exactly. Hope everyone drops the myth no filter should be the best.
Sportsguy83 is offline
The Following User Says Thank You to Sportsguy83 For This Useful Post:
tripjammer (07-31-2012)
Old 07-31-2012, 10:48 AM   #45
xjohnx
Grip>Slip
xjohnx's Avatar
Does these filter make the car run any smoother in the higher rpms?
You're welcome to snag the K&N from my BRZ and take your car for a spin if you'd like. It's a 30 second swap out.
xjohnx is offline
Hanzo (07-31-2012)
Old 07-31-2012, 11:03 AM   #46
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The best at sucking small rocks and bugs into your engine.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
kuhlka (12-05-2013)
Old 07-31-2012, 11:16 AM   #47
MarkMash
MarkMash's Avatar
Drives: Toyota 86
not sure if this has been asked yet - what's the sound difference like to stock? much different? better? louder? cheers
MarkMash is offline
Old 07-31-2012, 11:21 AM   #48
xjohnx
Grip>Slip
xjohnx's Avatar
K&N is slightly louder than stock.
xjohnx is offline
Old 07-31-2012, 11:24 AM   #49
YoKeutla
Drives: Scion FRS
There is a noticeable difference in sound. In my opinion, I think the motor sounds much better with the drop-in filter now. Before, you couldn't really hear anything with the exhaust being so quiet. Now you can really tell you are getting up in the rpm range and I think the engine doesn't sound as raspy in those high rpms.
Sponsored By: FT-86 SpeedFactory - http://ft86speedfactory.com
Cheers!:happy0180:
YO
YoKeutla is offline
The Following User Says Thank You to YoKeutla For This Useful Post:
Hanzo (07-31-2012)
Old 07-31-2012, 11:24 AM   #50
xjohnx
Grip>Slip
xjohnx's Avatar
I used photoshop to overlay the stock vs K&N run:
xjohnx is offline
The Following 10 Users Say Thank You to xjohnx For This Useful Post:
200hp/tonne (02-26-2014), bedabi (06-19-2013), Bonburner (08-01-2012), Brinks (07-23-2014), FT-86 SpeedFactory (07-31-2012), jimmillion (05-12-2015), Pascal_TTH (02-03-2013), SkitterSkotter (07-31-2012), Sportsguy83 (07-31-2012), YoKeutla (07-31-2012)
Old 07-31-2012, 11:31 AM   #51
E92M3Guy
Drives: BMW E92 M3
All three runs added to the FT86 Dyno Database:
http://www.ft86dynos.com
Stock:
http://www.ft86dynos.com/showDyno.php?recID=517
HKS Filter:
http://www.ft86dynos.com/showDyno.php?recID=518
K&N Filter:
http://www.ft86dynos.com/showDyno.php?recID=519
AFE Filter:
http://www.ft86dynos.com/showDyno.php?recID=520
E92M3Guy is offline
The Following User Says Thank You to E92M3Guy For This Useful Post:
Old 07-31-2012, 11:34 AM   #52
YoKeutla
Drives: Scion FRS
Might want to note that we were running on 91octane. 93 is not easily accessible where we are from
Cheers!:happy0180:
YO
YoKeutla is offline
The Following 2 Users Say Thank You to YoKeutla For This Useful Post:
E92M3Guy (07-31-2012), SkAsphalt (07-31-2012)
Old 07-31-2012, 11:56 AM   #53
E92M3Guy
Drives: BMW E92 M3
Fixed. Thanks.
E92M3Guy is offline
Old 07-31-2012, 12:22 PM   #54
Tainen
Drives: First SWP BRZ-L
Did you run each configuration 3 times on the dyno?(including baseline)
The reason I ask is, I've dyno'd my car like... 6 times now, and each time, the power fluctuates the first two runs and the 3rd run is the stable HP figure that is repeatable, and always the highest number as well.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline
The Following User Says Thank You to Tainen For This Useful Post:
ZetaPerformance (09-19-2012)
Old 07-31-2012, 12:51 PM   #55
d1ck
Drives: Black 2013 FRS
When you pinch off the end of a hose you're creating what's called a nozzle which reduces the cross sectional area which the water has to flow through. This is why the velocity increases. You can determine the velocity through a known opening by doing the following:
Code:
Velocity (ft/s)= Flow Rate(ft^3/s) / Area (ft^2)
However, you're not getting more flow by doing this, that literally makes no sense. Try breathing through a straw and you will know what I mean. It's much easier to breathe through your open mouth or nose which has a larger cross sectional area than a straw.
You're also creating a restriction which reduces the flow rate through the entire system system (Hose). Therefore by pinching the hose off you're increasing the velocity of the water, but also reducing the flow rate. The amount the flow rate is affected depends on the efficiency of the orifice as well as the area.
Now that you've (hopefully) learned some basic fluid dynamics you will understand why what you said has nothing to do with the increase from installing a filter.
That said, I can't explain why that happened, but I'm thinking it could be due to intake resonance which would have been designed with the filter in mind. Unfortunately I don't know anything about this field.
Alternatively it could be a simple artifact in the dyno testing and within the margin of error of the dyno. In this case it would have no significance.
d1ck is offline
The Following User Says Thank You to d1ck For This Useful Post:
theredtape (04-26-2013)
Old 07-31-2012, 01:02 PM   #56
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Code:
Interesting, I was thinking if you pinch down on a hose (not all the way down) your cross sectional area will still be the same since the hose would squash and widen (I may be wrong). Good info though, thanks!
Hanzo is offline
AT/MT Dyno Results with/without Mods blackfireball5 Engine, Exhaust, Transmission 0 07-04-2012 02:34 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
K&N Drop-In Filter for BRZ/FR-S in stock! Mach V Dan Engine, Exhaust, Bolt-Ons 0 06-27-2012 02:41 PM
Dyno results for the Nameless Performance street package! John@Nameless Announcements, Contests, Giveaways 31 06-26-2012 04:37 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
