Old 01-07-2022, 12:57 PM   #1247
RedReplicant
Drives: None
Just throwing in a dyno. This is the 85mm pulley on E60 with a super soft tune (by choice). Ace A350, Ace front pipe, and CSG Touring catback.
RedReplicant is offline   Reply With Quote
The Following 6 Users Say Thank You to RedReplicant For This Useful Post:
bhmax (01-07-2022), CSG Mike (02-03-2022), FunnyGopher (01-11-2022), grumpysnapper (01-07-2022), Irace86.2.0 (01-09-2022), PulsarBeeerz (01-08-2022)
Old 01-10-2022, 07:32 PM   #1248
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by ajc209 View Post
Nope. I have a mate with this kit. IATs are solid at around +25C over ambient all day.
He running harrop stock pulley. Stock exhaust, stock suspension but running on 225 MPSS tyres and sti Brembo brakes. Also has 4.67 final drive. He was going quickly pushing the kit hard.
Sorry, who has 4.67 final drive + SC?
I found an used one 4.67FD with ATS 1.5Way but I am not sure if I should put it on. Afraid is FD is too high and cannot make good use of the power.
I have a cosworth SC as well.
Thanks!
botbs is offline   Reply With Quote
Old 01-12-2022, 05:56 PM   #1249
mabviper
Drives: WRB BRZ
I have a Harrop 85mm with a 4.67 FD. It depends on what you're going to do with it. On the street, it's fine. On autox, it's pretty fun. On the race track, it really depends on the track. It can make it too short or make it just right. You'd have to experiment. It makes it feel~ faster since you're going through gears quicker but it may not actually be faster.
mabviper is offline   Reply With Quote
The Following User Says Thank You to mabviper For This Useful Post:
botbs (01-12-2022)
Old 01-12-2022, 06:19 PM   #1250
botbs
botbs's Avatar
Great! I am getting it then =)
This car is all about driving feel, Thanks for your input!
Toyota Camry always passed me on HWY (I thought I was driving fast but it is not )
Did you retune your ECU to match the 4.67FD or you can just plug and play the FD without retune the ECU?
Thanks again!
Old 01-12-2022, 09:01 PM   #1251
mabviper
Drives: WRB BRZ
You kinda need to retune. Your tuner needs to modify the gear ratio tables. They may charge for it even though there's no engine tuning involved. I know my tuner didn't want to give me 2 tunes, one for 4.3 and another for 4.67. If you don't correct it, you gear indicator in the dash will read wrong.
botbs (01-13-2022)
Old 01-13-2022, 12:52 AM   #1252
botbs
botbs's Avatar
If it is only the gear indicator is wrong, I am not too concerned because I turn the indicator off normally.
But if there is other things that screw up on the tune, then I might have to think about it again.
Thanks!
Old 01-13-2022, 11:57 AM   #1253
RedReplicant
Drives: None
I was hoping to get down to about 300whp, but clearly I was overly optimistic.
Same dyno, same fuel, 90mm pulley, and a small tune tweak from CSG.
Not sure what to do at this point short of paying CSG to do a flat tune, I need to be making about 300 peak and I want to keep the ethanol for safety on track.
The Following User Says Thank You to RedReplicant For This Useful Post:
FunnyGopher (01-15-2022)
Old 01-13-2022, 06:34 PM   #1254
cjd
cjd's Avatar
Drives: 2017 BRZ
smaller front-pipe?
Old 01-13-2022, 11:32 PM   #1255
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by cjd View Post
smaller front-pipe?
Adding exhaust restriction as a means to reduce power is generally a bad idea.
PulsarBeeerz is offline   Reply With Quote
Old 01-14-2022, 09:37 AM   #1256
cjd
cjd's Avatar
Drives: 2017 BRZ
Sure, but sometimes rules make for such things. Not sure that's the case here...
Old 01-14-2022, 11:40 AM   #1257
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I presume the tune tweak from CSG was tweaking the ignition timing or richening up the AFR a bit. The problem with trying to de-tune it may be getting to a point where the loss of fuel efficiency and/or other reliability issues from running too rich (E.G. fouling plugs, cylinder wall washing from excess fuel causing ring wear / poor sealing, etc.) outweigh the specific power goal.
I also don't think adding exhaust restriction is a great way to go because of the added strain on components upstream from that restriction with boost. If anything, maybe a restrictor plate on the intake side (at the throttle body or somewhere along that path) might be a better way to go.
That's what they used to do on the WRC cars (and possibly still do?) and in many various touring car series to limit peak power to a specific output while still getting the most low-mid range power.
Other than that, maybe a 95-ish mm diameter larger pulley for slightly less boost? Not sure if that would have to be a custom job or not, as I have no idea what other pulleys are available from Harrop. That would then allow the tune to be "maxed out" and efficient, but keep power levels within your desired range. EDIT: just saw that dropping from 85 to 90mm only gave you a 5 whp drop, so probably an even larger pulley than 95mm would be needed...100 or 105mm? You'd then be dropping way out of the efficiency range of the blower, probably. Could be that an intake restrictor plate may be the better way to go.
Last edited by Tatsu333; 01-14-2022 at 12:21 PM. Reason: Edited for suggested pulley size
Tatsu333 is offline   Reply With Quote
Old 01-14-2022, 11:53 AM   #1258
RedReplicant
Drives: None
That's what they used to do on the WRC cars (and possibly still do?) and in many various touring car series to limit peak power output while still getting the most low-mid range power.
Yeah, I talked to CSG yesterday. I'm going to rent the dyno and CSG will play with timing / cam timing to tame the top end. Harrop does offer a 95mm pulley, however the ideal thing would be to run the smallest pulley possible and neuter the top end for the most area under the curve.
I'll be playing it safe and staying with the 90mm for now.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
bhmax (01-16-2022), CSG Mike (02-03-2022)
Old 01-14-2022, 12:43 PM   #1259
Tatsu333
The restrictor plate may be the way to go in that case, because it will limit the peak airflow up high but allow full power through the low to mid range. Because it's a relatively small level of restriction, it shouldn't result in a lot of excess heat or wear on the blower (I.E. it's not like you're restricting down a 400 hp potential to 300 hp). You could maybe even go back to the 85mm pulley if you went that route.
Good luck!
The Following User Says Thank You to Tatsu333 For This Useful Post:
bhmax (01-16-2022)
Old 02-03-2022, 05:05 PM   #1260
Tatsu333
Hmmm...interesting to note that Harrop no longer lists the FRS/GT86/BRZ supercharger kit at all on their websites (Australian or US). Maybe the "pause for retooling" is a permanent end to production?
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
