Old 01-03-2022, 06:38 PM   #127
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by FrickingReallySlow View Post
Check out the savage geese video they specifically mentioned this as well as other improvements in the gen2 trans when talking to their engineers. but yeah gen1 trans are now so cheap you can get 10 of those for the price of a new gen2
I believe all they did was shot-peening for the gears. I wouldn’t expect significant improvements to strength in those gears, but maybe all the little changes to all elements in the transmission will add up.
Old 01-03-2022, 08:21 PM   #128
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
IAG getting interesting…
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following 12 Users Say Thank You to BrahmaBull1990 For This Useful Post:
DarkSunrise (01-17-2022), DustinS (01-04-2022), Four_wheel_drifts (01-04-2022), jflogerzi (01-12-2022), kevaughan (01-07-2022), radroach (04-20-2022), RedReplicant (01-04-2022), sato (01-03-2022), Spankopotomous (01-18-2022), Spawn_Of_Creation (01-05-2022), T-Steve (01-23-2022), Tatsu333 (01-05-2022)
Old 01-05-2022, 12:05 PM   #129
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I was hoping someone would look at making a "kit" to make this relatively simple. Question now will be whether this will be a kit for a complete motor swap (and with or without all the ECU, electronics, etc.), long-block or short-block.
Fingers crossed this isn't just vaporware, because my ideal path is still a 2.4L swap rather than forced induction...
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
BrahmaBull1990 (01-05-2022)
Old 01-05-2022, 06:24 PM   #130
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I would love to keep my Edelbrock and just have the 2.0L heads machined and keeping using the SC. If not, I’ll just do a built IAG 2.0L.
The Following 4 Users Say Thank You to BrahmaBull1990 For This Useful Post:
cactus (01-05-2022), Jaden (01-06-2022), kevaughan (01-07-2022), Tatsu333 (01-06-2022)
Old 01-12-2022, 10:23 PM   #131
jflogerzi
jflogerzi's Avatar
Oh yes baby! Come on IAG. I will drop some coin on this if its cheaper than the K24 swap and dose not need significant re-wire etc...
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Tatsu333 (01-13-2022)
Old 01-14-2022, 12:25 PM   #132
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
My custom twin supercharger will likely bolt right up to the fa24, so if the swap becomes viable with or without the fa20 heads, it might be a go for me.
Although I would prefer to be able to use the fa20 heads, since I already have a spare set, could sell the working fa20 in the car and would only have to pay for an fa24 short block.
Jaden
Jaden is offline   Reply With Quote
Old 01-16-2022, 02:43 PM   #133
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
kevaughan is offline   Reply With Quote
Old 01-17-2022, 05:02 PM   #134
jflogerzi
jflogerzi's Avatar
Originally Posted by kevaughan View Post
4th gear vs 3 gear. Also He has a vortech which nothing is home down low but it does show what the new 2.4 can do. Can't wait to see it with Tune and e85 only.
Old 01-17-2022, 11:17 PM   #135
PulsarBeeerz
Drives: JRSC BRZ SOLD
Additionally the SC car only made 240whp on 91. Add the widebody and big heavy 3 piece IG wheels the result seems legit.
PulsarBeeerz is offline   Reply With Quote
The Following 5 Users Say Thank You to PulsarBeeerz For This Useful Post:
Goingnowherefast (01-18-2022), Jdmjunkie (01-17-2022), kevaughan (01-18-2022), meWant (01-19-2022), RedReplicant (01-18-2022)
Old 02-23-2022, 07:55 PM   #136
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any word from IAG about progress?
Old 02-24-2022, 04:39 PM   #137
Tatsu333
I emailed them maybe a month ago, and they wouldn't officially say they were even working on it. They just said "we're not working on anything for the new BRZ/GR86 yet".
Calum (02-25-2022)
Old 03-02-2022, 01:20 PM   #138
wparsons
wparsons's Avatar
The supercharger should bolt in place on the 2.4 using the 2.4 heads. The exhaust manifolds bolt right up from first gens.
From what earlier reports have shown, the crank trigger wheel isn't compatible with first gen ECU's, and it looked like the design is different enough that you can't just swap on a first gen trigger wheel. It looked like a second gen ECU is needed, but if someone is going to make parts that work with the first gen ECU and physically bolt to the 2.4 then it could get interesting.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
BrahmaBull1990 (03-03-2022), jflogerzi (03-03-2022)
Old 03-02-2022, 02:10 PM   #139
RedReplicant
Drives: None
Supercharger bolts to the intake ports, not the exhaust. Real test is the first gen intake manifold bolting on.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Brz-123 (03-02-2022)
Old 03-02-2022, 07:26 PM   #140
Brz-123
Exactly. The intake ports are different
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 11:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 01:33 AM
