Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-12-2022, 01:31 PM   #1
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Revs bouncing off 1k rpm when shifting to neutral
Title Edit: RPMs* bouncing off 1k rpm
Hi all,
Wondering if anybody has experienced this or knows the reasoning as to why this happens as I've found someone else with an aftermarket exhaust on their BRZ experiencing the same thing as me.
When I am driving in gear and shift to neutral to coast, the RPM will drop but bounce off of 1k before going back down.
I have 1800 miles that were all driven with a stock exhaust and I'm fairly certain I've never noticed this before until I installed my MXP catback last night.
Someone else told me that it seems to be normal and that the Hyundai i20n also experiences this. Could anybody confirm this and explain the reasoning why this happens? Thank you!
suhhh is offline   Reply With Quote
Old 01-12-2022, 01:40 PM   #2
mazeroni
Drives: 2013 Scion FR-S Series 10
GEN I does this. Usually it happens with the AC on due to the strain on the motor which has the tendency to dip the engine to around 500 rpm. So I think in that case it is to try and prevent a stall.
But it is most pronounced when backing into a space when doing a lot of quick short revs. The car will go to idle and then rev 3~4 times to around 1K before smoothing out. I suspect this behavior has to do with emissions and ensuring that any unburnt fuel combusts in the engine and not in or after the catalytic converter.
There might be other causes, but I think the reasoning of it being emissions related is pretty sound.
mazeroni is offline   Reply With Quote
The Following User Says Thank You to mazeroni For This Useful Post:
suhhh (01-12-2022)
Old 01-12-2022, 02:23 PM   #3
sds
Drives: '22 BRZ Limited 6MT
Normal. This happens in all my other manual cars.
sds is offline   Reply With Quote
The Following User Says Thank You to sds For This Useful Post:
suhhh (01-12-2022)
Old 01-12-2022, 03:07 PM   #4
suhhh
suhhh's Avatar
Thank you for this! Yes, I've talked with a few others and it seems like this is normal because of emissions. First time I've ever dealt with this on a car so I was just unsure
Old 01-12-2022, 03:07 PM   #5
suhhh
suhhh's Avatar
Appreciate it thanks! Guess I just didn't notice it until I installed my exhaust
Old 01-12-2022, 04:10 PM   #6
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Why are you doing this for though?
You're burning fuel while the engine is idling, and you don't have drive if you suddenly need it in case something unexpected happens.
Old 01-12-2022, 04:26 PM   #7
suhhh
suhhh's Avatar
Well in today's case, stop signs lol
Not throwing it in neutral on highway speeds, just residential roads when there is an upcoming stop
Old 01-12-2022, 04:31 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Ah gotcha.
Rev bouncing in first? jc7993 BRZ First-Gen (2012+) — General Topics 18 04-10-2019 12:44 PM
Accidentally shifting into Neutral Lakitu Engine, Exhaust, Transmission 13 04-18-2018 09:29 PM
Bouncing revs Ondreiko Engine, Exhaust, Transmission 40 08-11-2015 06:10 AM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 01:20 PM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-02-2012 12:54 AM
