| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Essex/AP Racing BBK for 2022 available now!
https://www.facebook.com/CounterSpac...3865820007298/
https://www.essexparts.com/my-vehicl...Subaru/BRZ/All ![]() Lookin mighty pretty Confirmed fitments (355mm): 9660 only confirmed fitments Factory 18" wheels 9668 only confirmed fitments Factory 18" wheels with 8mm spacer Both 9660 and 9668 confirmed fitments: Forgeline 17" w/ spacer (varies with offset and width) RAYS 57CR 18x9.5 RAYS 57DR 18x9.5 RAYS 57Extreme 18x9.5 TWS T66-F 18" all variants Last edited by CSG Mike; 01-10-2022 at 01:59 AM. |
| The Following 7 Users Say Thank You to CSG Mike For This Useful Post: | ForeverCar (01-07-2022), gcmak (01-10-2022), Jianlun (01-07-2022), Pat (01-07-2022), PNW Shaggy (01-07-2022), rb6freak (01-20-2023), soundman98 (01-09-2022) |
#2 |
Drives: 2022 BRZ and some other cars
Looks amazing! So awesome!
#3 |
#4 |
Drives: 2023 BRZ
So many good options. I see the Sprint kit isn't available for the second generation cars. Is that due to the increase in power causing the smaller, lighter rotors to heat check prematurely?
Director of Rocky Mountain 86CUP
#6 |
How should one decide 372mm vs 355mm front? Does 372mm push one to 19” wheels?
Of course, I’d like the lightest possible setup that does the job. However, future plans might have some big power & repeated high speed runs so also trying to plan for the future. |
#7 |
Drives: 2023 BRZ
Check out this thread. Specifically post #25:
https://r.tapatalk.com/shareLink/top...ink_source=app
#8 | |
Good to know 355mm should handle everything. Let’s see if I can build something to overwhelm it.
#9 |
Drives: 2022 BRZ
I don’t want to track the car, but I want to save some weight and reduce unsprung mass anyway. And I want them to fit 17x7.5 wheels.
The Essex product pages say various kits fit the factory 18 inch wheels. Do any fit 17 inch wheels? |
#10 | |
Both 355 and 372 will require 18" wheels for virtually all applications. The only 17" wheel that I know of that is in production that will clear these brakes are Forgelines, which run ~6k/set. With 18" wheels, most wheels should clear both calipers. Templates are available for both. If there's enough demand and folks are willing to crowdsource the info as they try it themselves, I'll happily keep a running list going for the next 5+ years. I'll start with what I've already tested. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ForeverCar (01-10-2022) |
#11 |
Unless you're ready to spring for some 17x7.5 Forgelines, you'll need 18" wheels.
#12 |
Do you happen to know which style of Forgeline in 17” clears the 355mm 9660? For 18”, I thought there’s a minimum width of 8.5” due to the forging used. 7.5” is available in 17”? That’d be awesome!
#13 |
Drives: 2022 GR86
| Essex/AP Racing Sprint Kit proven in endurance racing by Toyota engineers | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 01-15-2025 12:28 AM |
| AP Racing by Essex Brakes for the 2022 BRZ | JRitt | BRZ Second-Gen (2022+) — General Topics | 62 | 06-10-2024 09:14 PM |
| AP Racing by Essex Brakes for the 2022 BRZ/GR86 | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 05-13-2022 09:52 AM |
| AP Racing by Essex Brakes for the 2022 GR86 | JRitt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 69 | 02-14-2022 03:02 PM |
| RR-Racing Sport Performance and AP-Racing Essex Initial Comparison | Gear_One_Performance | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 04-20-2016 05:31 PM |
