Drives: 2013 white frs
I have a 2013 FRS with 60K miles on it, no mods, OFT tune only. Today driving home I was doing some spirited driving got the RPMS up but not for long and afterwards my car started to make a rattling noise. I didnt think too much of it, thought maybe a bolt came loose on some trim. So I drove it trying to get home maybe 5 miles or less, the rattling seemed to not get worse but I started noticing some power loss on acceleration. Then I came to a stop sign and the engine cut off, with the whole dash lighting up. Haven't been able to start the car since, the engine cranks but wont start. The error codes i got were P000A,P000B,P000C,P00D,P1603,P1604
Any thoughts? Help? I was researching and it sounded similar to a spun bearing/rod knock. Is it possible to happen that quick? Will the car not start at all if the bearing spun? I didn't have any prior noises or issues |
#2 |
Drives: '13 Whiteout
Yes sounds like it
#3 |
The first 4 codes are all cam position related so could be a sensor but a spun bearing could also trigger those codes.
The last two codes are starting issues so could be anything.
#4 |
Drives: 2013 frs base
Was the engine running rough before it cut off?
#5 |
#6 |
#7 |
#8 |
I uploaded some photos of the oil, oil pan, and pickup. Lots of small metal flakes nothing large except for silicone in the pickup. Is this pretty normal or another sign of failure? Im going to remove the timing cover tomorrow see if anything in there looks broken
#9 |
New motor comin up.
Did have the recall done? |
| The Following User Says Thank You to TommyW For This Useful Post: | Tcoat (01-08-2022) |
#10 |
#11 |
Drives: car
All that silicone on the factory motor, wow. Think I've seen a failure thread from a late '13-early '14 model, spun rod probably from the broken-off gasket material. Might have been a bad run on some of these motors.
Really seems like a greater failure point than any other thing on these engines (besides spitting rockers out) and surprised Toyota doesn't recognize it and start pulling engines. |
#12 | |
Unfortunately there is no such thing as the "perfect" manufacturing process and my guess is that the robot that initially applied the sealant screwed up just as bad as some of the techs did later. They had to have known about it but odds are it was easier (cheaper) for them to just let the few that may have had the issue through the system.
| The Following User Says Thank You to Tcoat For This Useful Post: | TommyW (01-08-2022) |
#13 | ||
#14 | |
| The Following User Says Thank You to dvsd1991 For This Useful Post: | Tcoat (01-08-2022) |
| Toyota 86 after crash engine wont start | maciekg9 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-16-2021 05:53 PM |
| Spun Rod Bearing? | itsAlex | Issues | Warranty | Recalls / TSB | 38 | 03-12-2021 10:03 PM |
| FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 07:39 PM |
| Engine failure - Spun rod bearing TWICE | dinoniel | Issues | Warranty | Recalls / TSB | 38 | 11-07-2016 02:17 PM |
| Spun Rod Bearing #4 | KE70 | Issues | Warranty | Recalls / TSB | 13 | 07-05-2016 04:17 PM |
