#211 | |
Drives: Q5 + BRZ + M796
#212 |
I did a little work on the car when I finished studying for my final tomorrow. I got the shifter and driveshaft in after having to go to the dealership to get some of those black washer/spacers; mine were practically glued to the stock rod and broken.
I wasn’t down for cutting the bracket like the directions said. I was going to just weld it real fast, but I would have had to swap guns and tanks and just said hell with it and put a kink in it to shorten it up. Seemed to work, and now the center console is a little more stable than it would have been without the bracket.
#213 |
I made a bracket for the FF sensor, and I mounted it to the manifold. I used a 90 degree 3/8 quick connect to 5/16 barb, and I have a straight connector coming in the mail to finish it off. I cut the stock line just behind the 5/16 quick connect, and I added the 3/8 piece, and it reached pretty easy.
A few shots of the rear lines. One is plugged and zip tied. The EVAP line is just vented and dumped. The feed line has a piece of one of the lines I pulled attached, so I can drain my tank of old E85 when I get the car all hooked up. I probably should have kept a longer line, so I could just do this easier from the engine bay off the other lines. Actually, I might do that with the extra fittings. Hmmm. Anyways, that is the current setup. I don’t think I showed the picture of the oil lines. 120 degree fittings on one side and 45s on the other side with a low profile 90 degree fitting to clear the stock airbox at the top.
| The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
#214 |
I haven’t updated this in a while. Holidays had me busy, and I was waiting on some parts.
I mounted the Haltech ECU in the glove box using some well-nuts to keep it in place. I cut the glovebox down to clear. I don’t use my glovebox for storage, so this wasn’t a big deal. I wanted it in a place with easy access, yet somewhat not obvious. It can’t be seen from the seats when opened. It was a tight fit routing the wiring harness and getting the old ECU to fit back in the bracket because of the harness going out the rear hitting the firewall.
#215 |
I worked on the intercooler piping. I am planning to just tape the pipes together, and then I’ll have them welded. I realized I needed a 90 3” elbow to clear the hood. All I had was two 45s. I’ll finish the intercooler piping later this week.
#216 |
I got the stainless steel elbows. I cut off the old wastegate pipe that was angled up and blocking the gap for the downpipe. I opened the hole back up and cut it all to clear. I decided to just MIG weld it myself. Then I wrapped it in heat wrap. The turbo then got permanently mounted. The last picture is the former position of the wastegate. The subframe cupped area lateral to the engine mounts, the one for the header/midpipe provides an excellent space for the inverted wastegate, so there is lots of clearance. I’ll be working on the downpipe and wastegate dump tube next.
#217 | |
Drives: 2017 Hot Lava 86
#218 | |
#219 |
Drives: 2016 Toyota 86
Looks like a tight fit for that turbo! Thanks for all the updates.
#220 | |
The downpipe should clear with a few centimeters all around after my provisions.
#221 | |
#222 |
I started with assembling the turbo AN lines and decided to tackle more of the IC piping instead of the downpipe. I’ll start that tomorrow.
#223 |
I got my 90 degree aluminum elbow today, so I was able to finish the intercooler pipes. The hood closes with room to spare. I just need to drill two holes for the BOV bung and IAT bung. The pipes can be removed, just in case anyone is thinking it wouldn’t.
I also finished all the major cuts and prep on the downpipe to frontpipe. I just need to do the dump tube. I have room for a flex tube for the downpipe, but not for the wastegate like I wanted, but it’ll be fine. Here are a few pics. Plenty of clearance on the downpipe.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | ML (01-08-2022) |
#224 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Irace86.2.0 (01-14-2022) |
| Tags |
| worst.build.ever. |
| KPower Industries K24 swap | PulsarBeeerz | Engine Swaps | 1801 | 04-15-2025 11:54 AM |
| Irace86.2.0 Build | Irace86.2.0 | Member's Car Journals | 195 | 03-25-2024 12:29 AM |
| Turbo or swap | Fastend | Forced Induction | 35 | 06-11-2020 07:12 PM |
| Built Turbo K24 Swap? | Calmwhiteguy | Engine Swaps | 31 | 02-13-2018 05:07 PM |
| IRACE86's Build | Irace86 | Member's Car Journals | 25 | 01-10-2017 04:35 PM |
