That stupid oil filter dribble tray
Always hated the ridiculous engineering compromise of having to add an extra seal via an extra spacer if we wanted an oil cooler sandwich plate on our engine.
Bit the bullet and cut away enough of the lip so that the sandwich plate can now sit where it is supposed to.... lower, more compact and making way more sense. |
| The Following 5 Users Say Thank You to grumpysnapper For This Useful Post: | BigTuna (01-03-2022), humfrz (01-03-2022), Ohio Enthusiast (01-03-2022), Silviacrazed (01-03-2022), VIP BRZ (01-03-2022) |
#2 |
Drives: 2018 BRZ
Cutting into the engine block, adventurous.
The cutout is only needed to fit the hoses? The rest of the sandwich plate clears the lip? |
#3 |
Drives: 2013 WRB BRZ
Interesting. I had the supports bend/crack on my spacer at the end of the season during a retorque. Thankfully, it was replaced under warranty, but I had to remove the system in order to continue driving the car for winter until the replacement came.
This would eliminate that issue.. I'd like to see it all put back together when you have that done. EDIT: Do you need a different length thread adapter though?
| The Following User Says Thank You to BigTuna For This Useful Post: | grumpysnapper (01-05-2022) |
#4 |
Great minds think alike! I did the same only I had a square Mishimoto plate so had to cut a little more out. If you zoom in you can see it. I agree with the adapter, spacer then filter it stood up to tall.
| The Following User Says Thank You to Grady For This Useful Post: | grumpysnapper (01-04-2022) |
#5 | |
Whoops, there went your warranty -
#6 |
ProCrastinationConsultant
lol. *warranty.
#7 |
| The Following 4 Users Say Thank You to Grady For This Useful Post: |
#8 |
#9 |
Drives: SWP BRZ
What warranty? we're all here to modify. lol
| The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post: | grumpysnapper (01-05-2022), soundman98 (01-04-2022) |
#10 |
No, Tuned and installed flex fuel at 3k miles. Turbo installed at 5k miles. Clutch lasted for a year after turbo install. It was when I replaced the tires the clutch did not have the holding power.
| The Following User Says Thank You to Grady For This Useful Post: | Wally86 (01-05-2022) |
#11 | |
It still has a slight lip, maybe 3-4 mm, to keep its strength and also still catch some dribble. If the sandwich and spacer use the same (1) centre bolt you will have to change it for a smaller one. They are very easy to find at parts stores, the thread is M20 1.5 and the normal (single) sandwich plate lenght (thicknesss) is fairly consistent across most Japanese cars |
#12 | |
Yeah, warranty...that boat sailed on the day I bought the car new... weighed it on the way home then drove it into my garage and proceeded to (cough) improve it... |
| The Following 2 Users Say Thank You to grumpysnapper For This Useful Post: | humfrz (01-05-2022), soundman98 (01-05-2022) |
#13 |
No its usually the complete hose mounting/thermostat etc area that fouls the lip, usually about a 1/3 of the sandwich plate.
| The Following User Says Thank You to grumpysnapper For This Useful Post: | Ohio Enthusiast (01-05-2022) |
#14 | |
| FS (MD): Grimmspeed Intake, Perrin Inlet/CAI Filter, Green Air Filter | s203.22b | Engine, Exhaust, Bolt-Ons | 1 | 03-08-2021 12:25 PM |
| TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development | hirollaz | Engine, Exhaust, Bolt-Ons | 0 | 03-15-2017 02:46 AM |
| FS: OEM All Weather Trunk Tray/Cabin Filter/Covercraft UVS100 Windshield Cover | SWPinATL | Interior Parts (Incl. Lighting) | 4 | 08-02-2016 04:23 PM |
| Stupid Question: When to change OEM intake filter? | m.wood0213 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-17-2014 07:35 AM |
