Old 11-26-2021, 08:23 PM   #127
quixeger
Drives: 2019 6MT on CSG flex A w/SX2s
Hi Folks, was there a solution? I've discovered the same rattle around 15k miles.
quixeger is offline   Reply With Quote
Old 01-02-2022, 12:34 AM   #128
mrmamba
mrmamba's Avatar
Drives: GT 86 2017
Originally Posted by FrickingReallySlow View Post
Necro thread... looking at the 2022 shifter linkage the pin holding the washer (no change) has been changed to a ring clamp. Otherwise everything looks the same although not the same part numbers.
https://parts.subaru.com/a/Subaru_20...11-350-01.html
I might order this ring clamp and see if it works better than trying to find a slightly thicker washer. not sure how such a tiny ring clamp works is it just one piece that's stretched to fit on?
Did you try It?
mrmamba is offline   Reply With Quote
Old 01-02-2022, 09:19 AM   #129
gpvecchi
gpvecchi's Avatar
In my lever, the rattle comes from the reverse spring that's inside the lever (and in fact the new one has it ouside the lever).
Old 01-05-2022, 06:53 PM   #130
FrickingReallySlow
Drives: 2015 FR-S
Originally Posted by mrmamba View Post
Did you try It?
This guys shows how that C Clamp ring is used. According to him the clamp may come lose too. Have to pushed it against the washer
FrickingReallySlow is offline   Reply With Quote
Old 08-16-2022, 12:48 PM   #131
LateOnTheBrakes
Drives: 2023 BRZ
Originally Posted by sav View Post
After getting two gear levers replaced the rattle kept coming back. I've eventually managed to fix it by getting to the root of the problem - the thin washer at the bottom of the gear lever under the car.
You'll see a split pin holding the gear lever to the rod on the gearbox. Remove it together with the thin washer and replace with a thicker steel washer and refit the pin. Problem solved.
( It's the joint right at the bottom of this pic that you're looking for.)
Pics from this thread:
http://www.ft86club.com/forums/showthread.php?t=31340
BTW.
I've sprayed some Liqui Moly Tacky Lube Spray in there as well for good measure.
EDIT:
Special thanks to @Freedom who noticed the loose washer.
Sorry to revive a dead thread but do you recall the inner diameter and thickness of the washer you used to stop the rattle?
LateOnTheBrakes is offline   Reply With Quote
Old 08-16-2022, 12:49 PM   #132
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
No idea unfortunately, I simply had one laying around which fit.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 08-16-2022, 01:10 PM   #133
gpvecchi
gpvecchi's Avatar
Mine is rattling from the reverse thing and from its spring inside the lever.
Can anybody suggest a PERMANENT fix? I'm tired of spraying grease every month...
Old 08-16-2022, 01:51 PM   #134
LateOnTheBrakes
Drives: 2023 BRZ
Do you have pictures? Were you able to fix it. I'm not sure which my 2015 FRS has. Nor am I sure how to disassemble this thing. Looks like a pin that needs to be drifted out.
Old 08-17-2022, 02:34 AM   #135
gpvecchi
gpvecchi's Avatar
No fix yet, except a lot of grease.
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 10:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 01:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 08:20 PM
