#43 | |
Drives: 2022 BRZ WRB
#44 | |
Drives: '22 BRZ 6MT MGM
It’s up to the amount of risk everyone is willing to take but that’s acceptable enough for me. As for fixed bucket seats and half/full cages, neither are acceptable for the street imo unless you’re running a full safety setup with a helmet etc. I’d argue that’s a terrible option vs the CS, even if it’s less money. |
#45 | |
Drives: 2022 GR86
It's even possible that the JDM Sportster CS for BRZ had airbags not available for sale other than through Subaru, and were only ever made in the RHD variant. That being said, it is possible that everything is fine; but I would strongly suggest doing more research on this topic. And when you do find anything useful, please share with us! While at it... any evidence that those Sportster CS seats actually provide any extra headroom? Yeah, that's a valid concern. |
#46 |
Drives: Too fast
The head room available is exactly the same as 1st gen. 100% identical.
#47 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
They are listed the same but the rear in the 2022 has less headroom, so it depends on your seating position because of the slope of the roof. In practice it’s definitely not identical, I took my car (2013 FRS, stock seats) three times to the dealer to try side by side and I definitely notice differences in headroom, as well as my second issue my right knee hitting the column in the 2022.
#48 |
Drives: Too fast
I think the 2022 has actually MORE headroom, as the hole over the head appears to be slightly deeper (ie thinner material)
I have been driving an FRS and a 86 for the last 6 years, and the 2022 now. Saying that there is less headroom is misinformation to other users. It is false. |
#49 | |
Drives: 2022 GR86
I felt that there was slightly less headroom in the 2022. Admittedly, I didn't put both cars side to side, and admittedly there's a difference between sitting in a stationary car in the showroom, and driving one on track. |
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | BRZZZZZZZZZZ (01-04-2022), Midnightsky (01-04-2022) |
#50 |
Car Nut
Alright I went to two dealers and took measurements this evening. I also brought a short friend to get a subjective view and verify measurements. We will start with my 13 FRS with stock seats and rails. With the seat at the lowest setting, seat back 20.5” from the steering wheel bottom with the column out and up all the way, there is 37.75” between the bottom back seat cushion centre to the headliner. Next we looked at a 22 Base BRZ Automatic with Eyesight, with again the seat all the way down, the column all the way out and up, and 20.5” from the bottom of the steering wheel to the seat back we measured 37.0”. This is where it gets interesting, next we looked at a 22 Base BRZ Manual and again with the column all the way out and up, seat back 20.5” from the bottom of the steering wheel and the seat cranked all the way down, we measured 37.5” from bottom back seat cushion centre to headliner. Previously I had only had the chance to sit in the automatic car 3 times so this was a big discovery for me.
Subjectively my friend agreed that there was a very noticeable difference in headroom between the 22 automatic car and my 2013 both him sitting in it and placing his hand above his head, and visually looking at my head when I sat in both cars. He also agreed there is a very small but still noticeable 1/4” minimum difference between the 13 and 22 manual cars. |
| The Following 5 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post: | Aroundomaha (01-30-2022), DocWalt (01-05-2022), dsc_pat (01-05-2022), Midnightsky (01-04-2022), Stonehorsw (01-06-2022) |
#51 | |
Drives: 2022 GR86
The BRZ I tried in the showroom was an automatic, so I'm now slightly more optimistic about the headroom in the manual. Another factor is that the seat isn't solid, so when one's butt presses into the seat, it squishes. It's hard to measure the exact headroom in such a situation, but the point is that the same "static" headroom might feel more roomy with a softer seat cushion than with a stiffer one. |
| The Following User Says Thank You to timurrrr For This Useful Post: | BRZZZZZZZZZZ (01-04-2022) |
#52 | |
Car Nut
| The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post: | timurrrr (01-04-2022) |
#53 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | BRZZZZZZZZZZ (01-05-2022), Midnightsky (01-05-2022) |
#54 |
Drives: Too fast
Wow. Fantastic info about the automatic. Explains a lot. Both my cars are manual.
Thanks for sharing ! |
| The Following User Says Thank You to dsc_pat For This Useful Post: | BRZZZZZZZZZZ (01-05-2022) |
#55 |
Drives: 2022 GR86
I drove my friend's 2022 GR86 Premium MT yesterday, and unfortunately there's definitely a little less headroom than on my 2017 BRZ Limited. I tried my best to have the exact same seating position. I can barely use in my helmet in my BRZ and in the GR86 I'd say the same helmet is borderline unusable. Probably only ~5-10mm difference in headroom, but in my case that was all that's needed. Tall buyers beware.
I'm 6'4" with more torso then legs. |
| The Following User Says Thank You to timurrrr For This Useful Post: | Aroundomaha (01-30-2022) |
| I finally found seats for big and tall people! | arkanist | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 11-26-2019 05:31 PM |
| How tall are you | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 122 | 12-26-2013 04:05 PM |
| Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
| Seat fit for tall people? | clubraf | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 06-29-2012 10:51 AM |
| How tall are you? | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 111 | 11-14-2011 03:32 AM |
