Drives: Toyota GT86 2012
Scary noise on cold start
Hello,
I’m slightly worried, as I just got a very strange noise. I started my 86 (1 week since last use) inside my garage (temperatures are pretty high for winter, 15°C/59°F). Motor revs to 1500, as usual, then I get a loud sound « ta-ta-ta-ta-ta-ta-ta ». Kind of like firecrackers, or when your exhaust has holes, but I’d say higher pitched. A bit metallic, but maybe that’s my mind. And definitely loud enough to be heard over the motor, with doors and windows closed. Anyway, it lasted maybe a 5 seconds, while I was WTF-ing, then it disappeared, RPM revved down to 1000, and I did not hear it anymore as I went shopping. How worried should I be? Edit: car is 2012, stock, and I pressed the clutch pedal during the sound and it did not seem to affect it. |
#2 |
Drives: 2013 frs base
What is the mileage (kilometerage?) on your engine? A video with sound would be helpful.
#3 |
~82000km. The recall was done last December.
I’ll try to start it every few days, with a phone ready to record, in case it repeats. |
| The Following User Says Thank You to Youx For This Useful Post: | Ultramaroon (12-31-2021) |
#4 |
Drives: '13 Whiteout
What oil are you using
#5 |
First guess would be a rod knocking until the oil pressure built up but your engine mileage is rather low for that.
#6 |
#7 |
Hmmm yeah plenty thin. You had the recall done and that's a red flag. If they let silicon get in the engine it may be clogging things up and compromising the oil flow. Keep an eye on it. Not much you can do if that's the case. Yes try starting it often to keep a film of oil on the bearings
#8 |
TRACKBREAD
If it keeps doing it, try priming the oil pressure when starting it cold. You do this by holding the gas pedal down when starting the car. It will crank, but not start until you take your foot off the gas. Let it crank ~3-5 seconds to let the oil pressure build up, then let it start.
#9 |
Will check back for the recorded sound.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (12-31-2021) |
#10 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | JD001 (01-16-2022), soundman98 (12-31-2021) |
#11 |
Sarcastic SOB
Maybe a piece of the cat honeycomb broke loose
| The Following User Says Thank You to wbradley For This Useful Post: | Ultramaroon (12-31-2021) |
#12 |
At this point, all I have is the mental picture of a man saying it with a French accent.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (12-31-2021), soundman98 (12-31-2021) |
#13 |
Famous Potatoes
Drives: '15 ultramarine
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#14 |
Professional wrench
Drives: 2020 BRZ ST RS
as a professional wrench, there are at least 5 normal issues that make this kind of noise. Its definitely a relevant thing to want to listen to it.
For example, is it a lifter not pumping up quickly? Or an exhaust manifold leak? Or a heat shield? Or an item stuck in the belt that flung itself out after a bit? All completely different diagnosis and prognosis. All to Tatatatatatata
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
| The Following 2 Users Say Thank You to JohnH For This Useful Post: | humfrz (01-06-2022), Ultramaroon (01-06-2022) |
| Transmission Noise in Neutral @ Cold Start | Jackal84 | Issues | Warranty | Recalls / TSB | 57 | 03-01-2021 03:21 PM |
| Cold start up popping noise | Weeber | Issues | Warranty | Recalls / TSB | 51 | 09-23-2016 12:54 PM |
| Perrin CBE crackling noise during cold start | tracerit | Engine, Exhaust, Transmission | 8 | 02-26-2015 03:43 PM |
| Rubbing noise on cold start only in reverse? | brsaresmgs | Issues | Warranty | Recalls / TSB | 2 | 01-18-2015 07:15 PM |
| Cold Start Clunk Noise | Luckrider | Issues | Warranty | Recalls / TSB | 6 | 11-28-2013 05:02 PM |
