Old 12-27-2021, 09:21 PM   #1163
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
rudder ya'll on about?
I think everyone is a bit cranked. The puns keep coming but there's clearly no planform it.
Also
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (12-27-2021)
Old 12-27-2021, 09:40 PM   #1164
soundman98
ProCrastinationConsultant
soundman98's Avatar
i feel like this thread is just taking off
Old 12-27-2021, 10:17 PM   #1165
spike021
spike021's Avatar
From Japanese car twitter: https://twitter.com/nqo________zn6/s...785412098?s=21
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 12-27-2021, 11:34 PM   #1166
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
What happened to the friendship
Old 12-28-2021, 08:06 PM   #1167
Spent a couple of hours today on the Lego LEM kit. There's some pretty interesting detail in the kit. They include the fuel tanks (don't shoot the red ones), the camera that shot the first steps, the laser project (which is removable and you can place on the "moon", and the plaque, which if this is accurate was behind the ladder (I did not know that). Last shot shows poor Buzz Aldrin, stranded on the Moon.
I guess Neil figured what who caused those errors on the nav computer after all....
soundman98 (12-29-2021), Spuds (12-29-2021), Ultramaroon (12-28-2021)
Old 12-28-2021, 08:33 PM   #1168
Love the gold bricks for the parts with the reflective mylar film heat shields.
One of the first models I ever built was the old Monogram lunar module back in 1968. If I recall it met with a fiery explosive death during an unreported space race disaster involving gasoline and firecrackers in about 1971.
Dadhawk (12-28-2021), soundman98 (12-29-2021)
Old 12-29-2021, 01:54 PM   #1169
All done and ready for display. The front of the ascent stage comes off so you can display it with the astronauts at the control. You can also detach the ascent stage and display it separately.
The Following 7 Users Say Thank You to Dadhawk For This Useful Post:
JD001 (12-29-2021), NoHaveMSG (12-29-2021), soundman98 (12-29-2021), Spuds (12-29-2021), Stephen W. (12-29-2021), Tcoat (12-29-2021), Ultramaroon (12-30-2021)
Old 12-29-2021, 02:01 PM   #1170
Most of my first ones were around that time. Never did the LEM but as mentioned did build the Saturn V. I had said Revell but now that I think about it, and looked it up, it was a Monogram.
I did build about a dozen paper LEMs given away by Gulf Oil at the time (like this one on eBay)
Old 12-29-2021, 03:17 PM   #1171
JD001
JD001's Avatar
Drives: Subaru BRZ
Conspiracy theories just re-enforced, no fluttering flag...
The Following 3 Users Say Thank You to JD001 For This Useful Post:
Dadhawk (12-29-2021), Spuds (12-29-2021), Ultramaroon (12-30-2021)
Old 12-29-2021, 03:44 PM   #1172
And the moon is apparently made of riveted battleship gray steel panels...
But I always thought the issue was the flag was fluttering....
JD001 (12-29-2021), soundman98 (12-29-2021), Spuds (12-29-2021)
Old 12-29-2021, 03:57 PM   #1173
JD001
JD001's Avatar
Drives: Subaru BRZ
Exactly, no fluttering flag.. I can't wait for the Chinese rover, on the dark side of the moon, to pull up to a drive through Maccy D's.. the 'Cube' is a drive through..
The Following User Says Thank You to JD001 For This Useful Post:
Old 12-29-2021, 06:56 PM   #1174
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Picked up some Perfect Plastic putty. It is water based so you can apply it to joints and then wipe the excess away with a wet cotton bud! Works amazingly for wing roots and 90 degree joints! Saved a ton of time with less sanding. That being said I am REALLY regretting my lazy decision to build the Academy 1/48 F-15 instead of ordering the GWH kit... lesson learned.
The Following 4 Users Say Thank You to Kiske For This Useful Post:
bcj (12-30-2021), Kaotic Lazagna (12-29-2021), soundman98 (12-29-2021), Tcoat (12-29-2021)
Old 12-29-2021, 07:03 PM   #1175
Originally Posted by Kiske View Post
Picked up some Perfect Plastic putty. It is water based so you can apply it to joints and then wipe the excess away with a wet cotton swap! Works amazingly for wing roots and 90 degree joints! Saved a ton of time with less sanding. That being said I am REALLY regretting my lazy decision to build the Academy 1/48 F-15 instead of ordering the GWH kit... lesson learned.
Attachment 208274
How is it for odour? My wife complains bitterly when I use my solvent based stuff.
Old 12-29-2021, 07:13 PM   #1176
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Well I only can compare it to a few model putties as anymore I use polyester body filler for anything big... or CA glue with an accelerator
But, I almost couldn't tell it had a smell in comparison to the same size tube of tamiya basic white putty (which is pretty similar to squadron white.) Like 1/3'd the odor when sniffing the tube. I'd say because it is water based and you can clean it up before (or after) it dries you would save quite a bit there just by having less product sitting on the kit itself.
The Following User Says Thank You to Kiske For This Useful Post:
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
