Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-21-2021, 03:12 PM   #1
LanceLane174
Drives: 2022 BRZ Limited WRB, MT
Remote Start on Manual Transmission
Has anyone installed a remote starter yet? Apparently the companies don't have the info out there yet for the 2022. I am hoping it is the same as the 2020, but you never know.
My guy says it won't be a problem once the companies update their info. He suggests Fortem Technologies. It makes sure the car is in neutral and not in gear.
LanceLane174 is offline   Reply With Quote
Old 12-21-2021, 07:44 PM   #2
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
How does it push the clutch in for you?
PhatFreshPrince is offline   Reply With Quote
The Following 3 Users Say Thank You to PhatFreshPrince For This Useful Post:
Alltezza (12-23-2021), soundman98 (12-21-2021), Yoshoobaroo (12-21-2021)
Old 12-21-2021, 08:20 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
It probably shorts the Clutch switch out to start.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
PhatFreshPrince (12-21-2021)
Old 12-21-2021, 08:59 PM   #4
LanceLane174
That is correct. Same as on any manual car.
The Following User Says Thank You to LanceLane174 For This Useful Post:
Old 12-22-2021, 12:23 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
Ah the new-window-in-the-garage-wall mod
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
DocWalt (12-22-2021), PhatFreshPrince (12-22-2021), Yoshoobaroo (12-22-2021)
Old 12-22-2021, 01:02 AM   #6
LanceLane174
All of them require you to leave the car on, out of gear and ebrake on. Get out if car and lock it. Then the engine turns off and allows you to 3 press the lock button when u want to start it. If someone unlocks it in between then it won't remote start. That keeps you from launching it through garage.
Old 12-22-2021, 01:46 AM   #7
soundman98
soundman98's Avatar
Depends on force of habit, and if there is a neutral indicator wire to connect to, and if the tech connects it.
I knew a guy that while still at MECA, a classmate of his launched his personal car through the door and off the loading dock while following the teachers instructions on manual trans installation technique
Ultramaroon (12-22-2021)
Old 12-22-2021, 02:20 AM   #8
This ^^^
It's doable but you better make sure it only fires under the right conditions. Twins have a neutral switch. Big plus.
soundman98 (12-22-2021)
Old 12-22-2021, 12:23 PM   #9
LanceLane174
Don't all cars have a neutral switch now.
People have been safely remote starting manuals for decades. Not sure why this became controversial.
Tcoat (12-22-2021)
Old 12-22-2021, 12:50 PM   #10
It shouldn't be controversial. Some guys just think that every single tech out there is totally incompetent and can't get a single thing right. The installation of these devices is very simple.
Old 12-22-2021, 05:07 PM   #11
LanceLane174
That's what I thought. I am just looking for someone that has done one on the new generation to make sure the instructions are the same as first gen.
Old 12-22-2021, 06:05 PM   #12
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
In one of the early threads, someone posted a youtube video of a Japanese company that installed their remote start in the car and it was working fine with the correct behavior. The car only starts if it's in neutral with the ebrake up.
I don't have the video, but it definitely exists. Just wait for your favorite aftermarket remote start maker to make one for this car.
Interceptor777 is offline   Reply With Quote
Old 12-22-2021, 06:25 PM   #13
falcon_wizard
Drives: BRZ 2013
I have one installed on my 13’ manual BRZ, it works as described above. Basically leave it running in neutral with parking brake on, get out close the door and hit « shut down », and it will activate either righ away or after a 3min timer (nice to cool down the turbo) It was a more complex install so they had their most experienced tech do it, but otherwise it works, although there are a few quirks, like I found out that if I open the trunk to grab my stuff after pressing the « shutdown button » the car never shuts off after the timer expires and just keeps running. I also have a cellular antenna to start it from my cell as well. One downside if you live in a cold area in winter is that it can puts an additional drain on your battery if you drive the car too often.
Cheers
falcon_wizard is offline   Reply With Quote
Remote start on BRZ ZD8 Stonehorsw BRZ Second-Gen (2022+) — General Topics 8 09-29-2021 08:17 PM
Remote start lorip713 Electronics | Audio | NAV | Infotainment 5 01-29-2018 01:18 AM
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 03:43 PM
Remote Start on a Manual Transmission Iceman-86 Scion FR-S / Toyota 86 GT86 General Forum 15 03-12-2014 09:40 AM
Remote start Flako Electronics | Audio | NAV | Infotainment 4 11-26-2013 03:32 PM
