Old 12-16-2021, 04:14 PM   #1
jaiiwa
Drives:
Header to engine block nuts stuck
So I’m trying to install my PLM UEL headers on my FR-S, but I cannot get the nuts that hold the headers onto the engine block off. I’ve tried mostly everything. Torch, PB blaster, and lots of effort. Despite all of this, I’ve made no progress. Not sure where to go from here so if any of you have any suggestions I’d really appreciate it.
jaiiwa is offline   Reply With Quote
Old 12-16-2021, 04:20 PM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Maybe plain old elbow grease.
Old 12-16-2021, 04:21 PM   #3
jaiiwa
Drives:
I could probably use a torque wrench and pull a bit harder, I’m just afraid I might break one of the studs
Old 12-16-2021, 04:38 PM   #4
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
That`s the scary part. I used a breaker bar on mine but they were not very old and still quite locked on.
Old 12-16-2021, 04:43 PM   #5
jaiiwa
Drives:
How badly seized were yours?
Old 12-16-2021, 07:51 PM   #6
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Mine were not seized just very tight to crack loose
Old 12-16-2021, 08:22 PM   #7
jaiiwa
Drives:
Ah I see. Any idea if I could just take it into a muffler shop and only have them take off the nuts. I want to rlly just send it with a breaker bar but I’m afraid I’ll strip the nuts to no return
Old 12-16-2021, 08:23 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Heat and beat.
Penatrent, some heat, and an impact. With corroded fasteners you want to shock them. Dont' hit them too hard with the impact though you don't want to bust them completely.
Old 12-16-2021, 09:41 PM   #9
jaiiwa
Drives:
Heat and beat.
You don’t think an impact might break the stud?
Old 12-16-2021, 10:27 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
you definitely don't want to be using a torque wrench in this case.
https://en.wikipedia.org/wiki/Torque...%20application.
Old 12-17-2021, 07:27 AM   #11
tobin
tobin's Avatar
Drives: '13 BRZ
Maybe try driving the car for a bit, get the parts nice and hot, and try again (carefully). Good luck.
tobin is offline   Reply With Quote
The Following 2 Users Say Thank You to tobin For This Useful Post:
NoHaveMSG (12-17-2021), Ultramaroon (12-17-2021)
Old 12-17-2021, 08:30 AM   #12
StraightOuttaCanadaEh
Wes
I make my mechanic do everything. I sit in the waiting room and the parts are magically on the car shortly after. Not sure if anyone else has discovered this trick?
Instagram: @gt86ws
The Following 4 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (12-17-2021), meWant (12-18-2021), soundman98 (12-17-2021), Tcoat (12-17-2021)
Old 12-17-2021, 08:42 AM   #13
Grady
Grady's Avatar
Not no but Hell No on that one.
Heat it, Penetrant it, twist it, rinse and repeat until it comes loose or breaks. If the stud breaks no big deal just replace the stud.
Old 12-17-2021, 11:05 AM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
I hope it's for pay, not at gunpoint.
Seriously though, if unsure just take it to a muffler shop where they know what they're doing.
When I did mine car was maybe 2 years old and I sprayed it with release stuff and let it get right in for a few minutes then I was able to break them free with a socket wrench and a bit of muscle.
wbradley is online now   Reply With Quote
WRX Manifold on FRS engine block jakezitcovich Forced Induction 15 07-16-2020 05:09 PM
Can you tell year if an engine by the engine block number? guybo Engine, Exhaust, Transmission 18 07-22-2018 10:53 AM
Engine long block derek1ee Want-To-Buy Requests 0 02-29-2016 10:51 PM
Engine block heater project d CANADA 17 03-11-2013 12:04 PM
Engine Block # ichitaka05 Engine, Exhaust, Transmission 23 05-06-2012 05:33 PM
